BT.com
Wishlist
TP LINK AV1200 Gigabit Powerline Adapter Kit with 1 Port
TP LINK AV1200 Gigabit Powerline...
£63.60
£63.60
Add to wishlist
Delivery
Standard Due date unavailable
Advanced HomePlug AV2 technology means the TL-PA8010 KIT supports 2 x 2 MIMO, so users benefit from ultra-fast data transfer speeds of up to 1200 Mbps. Perfect for bandwidth demanding activities like streaming Ultra HD video to multiple devices simultaneously, online gaming and large file transfers.
With one Gigabit Ethernet port, TL-PA8010 KIT allows users to connect a bandwidth intensive device to the Internet at high speeds and ensures the smooth transmission of Ultra HD video streaming. This makes the TL-PA8010 KIT the perfect home entertainment companion.
Connect a powerline adapter to the router; plug another powerline adapter into a wall socket in another room, and connect it to your Internet enabled device via Ethernet - and you're done!
TP-LINK TL-PA8010 KIT - Starter Kit - bridge - wall-pluggable
Bridge
Packaged Quantity
2 (specifications are for single item)
Enclosure Type
Wall-pluggable
Ethernet, Fast Ethernet, Gigabit Ethernet, HomePlug AV (HPAV), HomePlug AV (HPAV) 2.0
Data Transfer Rate
1.2 Gbps
Routing Protocol
IGMPv2, IGMP, IGMPv3
Quality of Service (QoS), 2T2R MIMO technology, Type of Service (ToS)
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, HomePlug AV, HomePlug AV 2.0
AC 230V (50 Hz)
12.3 cm x 6.8 cm x 3 cm
Apple MacOS, Linux, Microsoft Windows Server 2003, Microsoft Windows 2000/XP/Vista/7, Windows 8, Windows 8.1
Packaged Quantity
Bridge
Enclosure Type
Wall-pluggable
Wired
Data Transfer Rate
1.2 Gbps
Routing Protocol
Encryption Algorithm
128-bit AES
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, HomePlug AV, HomePlug AV 2.0, Plug and Play, RoHS
Status Indicators
Power, LAN
Line Properties
Line Coding Format
OFDM
LAN: 1 x HomePlug AV 2.0 , LAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45
Internal power supply
AC 230V (50 Hz)
5.7 Watt
1 x network cable - 2 m
12.3 cm
6.8 cm
3 cm
10 - 90% (non-condensing)
Scroll to top
