BT.com
Wishlist
TP LINK AV1200 3-Port Gigabit AC1200 Wi-Fi Powerline Starter Kit
TP LINK AV1200 3-Port Gigabit...
£103.18
£103.18
Add to wishlist
Delivery
Standard 1-3 working days
  • AC1200 Dual band Wi-Fi - delivers combined speeds of up to 1200Mbps, providing fast and seamless network for multiple devices
  • AV1200 Powerline Speed - Fully meet the demand for bandwidth-intensive activities with ultra-fast powerline transfer speed of up to 1200Mbps
  • Wi-Fi Clone - Automatically copies the network name (SSID) and password of your router with the touch of the Wi-Fi clone button
  • Wi-Fi Auto-Sync - Makes it easy to add additional extenders to your powerline network by uniformly syncing settings such as SSID, password, Wi-Fi Schedule and LED Schedule for all network devices
  • Plug, Pair, and Play -Set up your powerline network and start enjoying fast, seamless wired/wireless connections in a matter of minutes
The TL-WPA8630 KIT expands your home’s Wi-Fi coverage into areas where the wireless signal from the main router is weak or nonexistent. The range extender kit can build a unified network using your home’s existing powerlines and allow you to enjoy Wi-Fi coverage in any area with a power outlet.
Instant Wi-Fi in Any Room
The TL-WPA8630 utilises 802.11 ac Wi-Fi to deliver dual band connections with combined speeds of up to 1200 Mbps, including 867 Mbps on the 5 GHz band and 300 Mbps on the 2.4 GHz band. The combination of impressive speed and convenient powerline networking allows you to provide fast, reliable connections throughout your entire home. This is perfect for 4K streaming and online gaming, on multiple devices at the same time.
Fast Dual Band Wi-Fi Speeds – Up to 1200Mbps
Advanced HomePlug AV2 technology means the extender supports 2x2 MIMO* with beamforming, so users benefit from ultra-fast data transfer speeds of up to 1200 Mbps. Perfect for bandwidth demanding activities like streaming Ultra HD video to multiple devices simultaneously, online gaming and large file transfers.
2X2 MIMO with Beamforming
More Stable Connections - 2X2 MIMO is like adding extra lanes to a highway. It establishes multiple simultaneous connection for you to enjoy higher speeds and greater stability. 2X2 MIMO with Beamforming Technology also offers the benefit of improved coverage throughout the home, particularly for previously hard to reach outlets.
Build a Larger Powerline Network with Wi-Fi Auto-Sync
Adding additional Powerline extenders is as simple as the initial setup. It is as simple as Plug, Pair and Play. Once this process is complete, you can manage the entire Powerline network from any extender and the changes will be implemented on all network devices instantaneously.
More Gigabit Ethernet Ports, More Devices
Equipped with three gigabit Ethernet ports, TL-WPA8630 allows you to connect several bandwidth intensive devices such as game consoles, smart TVs or media receivers to the Internet at high speeds, just plug in network cables and enjoy fast and stable wired network anywhere at home.
Easily Turn Off Blinking LEDs
You can easily turn off the LED indicators by pressing the LED On/Off button or control them remotely using the tpPLC App on your mobile device or the tpPLC Utility on your computer.
TP-LINK Powerline AV1200 - Gigabit ac Wi-Fi Kit - bridge - 802.11a/b/g/n/ac - wall-pluggable
Bridge
Enclosure Type
Wall-pluggable
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, HomePlug AV (HPAV), HomePlug AV (HPAV) 2.0, IEEE 1901, IEEE 802.11ac
Frequency Band
2.4 GHz / 5 GHz
Data Transfer Rate
1750 Mbps
Network / Transport Protocol
CSMA/CD
Routing Protocol
IGMPv2, IGMP, IGMPv3
Remote Management Protocol
HTTP
MAC address filtering, firmware upgradable, Quality of Service (QoS), reset button, 2T2R MIMO technology, Type of Service (ToS)
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
6.8 cm x 4.5 cm x 14.06 cm
Apple MacOS, Linux, Microsoft Windows XP / Vista / 7 / 8 / 8.1 / 10
Bridge
Enclosure Type
Wall-pluggable
Wireless, wired
Frequency Band
2.4 GHz / 5 GHz
Data Transfer Rate
1750 Mbps
Max Range Indoors
300 m
CSMA/CD
Routing Protocol
HTTP
Encryption Algorithm
WPA, WPA2, 128-bit AES, WPA-Enterprise, WPA2-Enterprise, WEP
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, Plug and Play, RoHS
Built-in Devices
Led panel
Status Indicators
Power, LAN, wireless
Line Properties
Line Coding Format
OFDM
LAN: 3 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , 1 x HomePlug AV 2.0
Internal power supply
10.8 Watt
TP-Link TL-PA8010P
2 x network cable - 2 m
6.8 cm
4.5 cm
14.06 cm
10 - 90% (non-condensing)
Other bundles
TP LINK AV1200 3-Port Gigabit AC1200 Wi-Fi Powerline...
£103.18
C2G 2m Cat5e Cable with Homeplug
Save £2.00
£106.66
Scroll to top
