BT.com
Wishlist
TP LINK ADSL2+ Ethernet/USB Modem Router
Delivery
Standard Due date unavailable
ADSL2+ Ethernet Modem Router TD-8817 is a high performance modem router that provides a full rate of ADSL2+ standard with the superb reliability and a cost-effective solution for home and small business. It is a 2-in-1 device that combines the function of a high-speed DSL modem and a one-Port 10/100Mbps NAT router.
Using the TD-8817, you can easily create a secure and high-speed wired network to share files, music, photos, and printers with multiple computers.
2-in-1 Solution
As a 2-in-1 device, TD-8817 combines the functions of a high speed DSL modem, and a one-Port 10/100Mbps NAT router. No need to buy a separate router, the TD-8817 is designed to give you a perfect solution to acquiring and sharing high speed Internet access. Then you could save the cost of procurement and the cost of device running.
Access High-Speed Internet
Unlike a dial-up Internet service, a DSL Internet connection is always on so that you do not have to wait to access the web. Supporting the latest ADSL standard, the TD-8817 provides higher performance (up to 24Mbps downstream) and longer reach from the central office of your ISP(Internet Service Provider).
Advanced Network Security
Support NAT firewall, TD-8817 could prevent potential attacks from across the Internet. For added convenience, it supports access control based on MAC address, IP address, domain name or application so parents and network administrators can establish restricted access policies for children or staff.
Quality of Service
Built-in QoS engine provides various QoS policies that help prioritize Internet traffic to enable smooth IPTV streaming and lag-free online gaming. Thus users could experience the benefit of smooth network connection without concern of traffic congestion.
Easy to Use
The device comes with a CD with an Easy Setup Assistant that helps you step by step to complete your Internet connection and security configurations. This feature allows even novice users to setup the router products without sacrificing any key features, just play the AUTO-RUN CD bundled to have your network set up quickly & hassle-free.
TP-LINK TD-8817 - router - DSL modem - desktop
Router - DSL modem
Enclosure Type
Desktop
Digital Signaling Protocol
ADSL2, ADSL2+
WAN Ports Qty
1
Ethernet, ATM, Fast Ethernet
Network / Transport Protocol
TCP/IP, PPTP, UDP/IP, L2TP, IPSec, PPPoE, PPPoA, AAL5, ARP, DHCP, DNS, DDNS
Routing Protocol
RIP-1, RIP-2, static IP routing
Remote Management Protocol
SNMP 1, SNMP 2, Telnet, HTTP
Firewall protection, NAT support, NAPT support, Stateful Packet Inspection (SPI), packet filtering, Quality of Service (QoS), virtual server support, DHCP server
IEEE 802.3, IEEE 802.3u, IEEE 802.1D, IEEE 802.1p
16.5 cm x 10.8 cm x 2.8 cm
Router
Enclosure Type
Desktop
Wired
Routing Protocol
Status Indicators
Power, link/activity
Line Properties
Framing Format
ANSI T1.413
Communications
DSL modem
ADSL2, ADSL2+
Protocols & Specifications
ITU G.992.1 (G.DMT), ITU G.992.2 (G.Lite), ITU G.994.1 (G.hs), ITU G.992.3 (G.DMT.bis), ITU G.992.5
Max Transfer Rate
24 Mbps
1 x 10Base-T/100Base-TX - RJ-45 , WAN: 1 x ADSL2+ - RJ-11 , USB: 1 x
External power adapter
ADSL splitter
1 x network cable , 2 x phone cable , 1 x USB cable
Software Included
Drivers & Utilities
16.5 cm
10.8 cm
2.8 cm
55 °C
0 - 95% (non-condensing)
Accessories
£4.95
£3.84
£11.41
C2G 2m Cat6a Shielded Patch - Blue
Quicklinx: 8H10 | In Stock
£8.16
£51.70
Scroll to top
