BT.com
Wishlist
TP LINK AC1750 Wireless Dual Band Gigabit Router - V2.0
TP LINK AC1750 Wireless Dual Band...
£78.55
40 in stock
£78.55
Add to wishlist
Delivery
Standard 3-5 working days
V2.0
802.11ac - The Next Generation of Wi-Fi
TP-LINK's Archer C7 comes with the next generation Wi-Fi standard - 802.11ac, 3 times faster than wireless N speeds and delivering a combined wireless data transfer rate of up to 1.75Gbps. With 1.3Gbps wireless speeds over the crystal clear 5GHz band and 450Mbps over the 2.4GHz band, the Archer C7 is the superior choice for seamless HD streaming, online gaming and other bandwidth-intensive tasks.
1.75Gbps Dual Band Connections for Lag-Free Work and Entertainment
The Archer C7 operates over both the 2.4GHz and 5GHz bands, ensuring amazing wireless performance. Simultaneous Dual Band offers you the flexibility of two dedicated networks - with multiple times the bandwidth for your needs. Simple tasks like sending e-mails or web browsing can be handled by the 2.4GHz band while bandwidth intensive tasks like online gaming or HD video streaming can be processed by the 5GHz band - all at the same time.
6 Antennas for Fully Expanded Coverage
With 3 external 5dBi antennas serving the 5GHz band and 3 internal antennas serving the 2.4GHz band combined with higher quality antenna technology, you can maintain high speeds across greater distances. This provides you with incredible wireless coverage and reliability from anywhere in your large home or office.
Full Gigabit Wired Connections for Ultrafast Data Transfer Speeds
With one gigabit WAN port and four gigabit LAN ports, speeds can be up to 10× faster than standard Ethernet connections. The Archer C7 is a powerful hub to support a robust and extremely fast wired network.
Dual Multifunctional USB Ports for Storage and Sharing
With the two multi-functional USB 2.0 ports, you can share printers, files and media with different devices through your local network or via the ftp server while away from home.
Guest Network
Guest Network Access provides secure Wi-Fi access for guests sharing your home or office network.
Easy Set-up
Included in the resource CD, TP-LINK's optimized configuration utility can help users complete the entire software installation and wireless network settings in just a few minutes.
IPv6 Supported
Archer C7 supports IPv6, which is foundational to the next generation Internet and enables a range of new services and improved user experiences.
TP-LINK Archer C7 AC1750 - wireless router - 802.11a/b/g/n/ac - desktop
Wireless router - 4-port switch (integrated)
Enclosure Type
Desktop
WAN Ports Qty
1
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Frequency Band
2.4 GHz / 5 GHz
Data Transfer Rate
1.75 Gbps
Network / Transport Protocol
PPTP, L2TP, IPSec, PPPoE, DDNS
Routing Protocol
Static IP routing
Firewall protection, DMZ port, Stateful Packet Inspection (SPI), print server, MAC address filtering, IPv6 support, parental control, Wi-Fi Multimedia (WMM) support, virtual server support, Wi-Fi Protected Setup (WPS), DHCP server, FTP server, bandwidth control, IPv4 support, port triggering, dynamic IP mode, DHCP client
IEEE 802.11a, IEEE 802.11d, IEEE 802.11g, IEEE 802.11n, UPnP, IEEE 802.11ac
24.3 cm x 16.06 cm x 3.25 cm
UNIX, Apple MacOS, Novell NetWare, Linux, Microsoft Windows NT / 2000 / XP, Microsoft Windows Vista / 7 / 8
Enclosure Type
Desktop
Wireless, wired
Frequency Band
2.4 GHz / 5 GHz
Data Transfer Rate
1.75 Gbps
Routing Protocol
Static IP routing
Encryption Algorithm
128-bit WEP, 64-bit WEP, WPA, WPA-PSK, WPA2-PSK
IEEE 802.11a, IEEE 802.11d, IEEE 802.11g, IEEE 802.11n, UPnP, IEEE 802.11ac, FCC, RoHS
LAN: 4 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , USB 2.0: 2 x 4 pin USB Type A
Aerial
Aerial
External detachable and internal
Antenna Qty
6
Directivity
Omni-directional
Gain Level
5 dBi
External power adapter
24.3 cm
16.06 cm
3.25 cm
10 - 90% (non-condensing)
Accessories
C2G 2m USB 2.0 A/B Cable - Black
Quicklinx: 63M8 | In Stock
£3.75
C2G 5m USB 2.0 A/B Cable - Black
Quicklinx: 63MW | In Stock
£5.32
C2G 2-Port USB 2.0 Manual Switch
Quicklinx: 6874 | In Stock
£21.09
£14.71
C2G 4-Port USB 2.0 Aluminum Hub
Quicklinx: 7BB4 | In Stock
£28.29
C2G 12m USB 2.0 A/A Active Extension Cable
Quicklinx: 7BB8 | In Stock
£19.30
C2G USB Superbooster Extender Kit
Quicklinx: 7H7B | In Stock
£37.30
£59.58
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
5* Decent Router
Reviewed by Nelson SHA on 15/07/2014
Vastly increased my wireless speed / range. If there is one comment I would make, which isn't about the product - don't buy from Kikatek - the delivery company they use is poor - they left my item IN the dustbin which was due to be collected the next day.
5* TP-Link Router
Reviewed by Anonymous on 02/04/2015
Ordered this from Bt Shop, it arrived within the 4 days as promise, the box had a dent in it, but luckily the router was undamaged.
I upgraded from a Netgear DGN3700v1 because the QOS was useless, the Tp-Link Archer C7 AC 1750router is really great because you can control the download speeds as well as the upload speeds for individual users, where as the Netgear only controls upload.
Very useful as teenagers tend to hog all the internet bandwidth.
Looks I like, some people will some wont, build quality seems good and reliability on 2.4 wireless is very good and has not suffered any drop outs, have used the 5ghz wireless seems ok.
The router was very easy to set up and this was set up on BT Infinty,
Hint -The bandwidth control just remember reserve a ip then bind a mac address to an ip.
The Tp- Link AC archer C7 Runs so much cooler than the very hot Netgear
For future proofing it also supports IPV6 and the Netgear DGN3700 v1 doesn’t.
4* Great router lots of setting
Reviewed by J.I on 06/07/2014
Really like this router easy to setup and all the settings seemed pretty straight forward
Works well with all my wireless access points and switches.
2* TP LINK AC1750 Wireless Dual Band Gigabit Router
Reviewed by Anonymous on 03/07/2014
Overpriced. Promises a lot but comes up short on delivery. The parental and access controls are clunky. I especially do not like the fact that in places I had to manually put in MAC addresses. You would think they would be in a drop down list. In other menus they are. Really not happy with purchase. There are routers half the price that deliver more
Scroll to top
