BT.com
Wishlist
TP LINK 300Mbps Wireless N AP/Client Router
Delivery
Standard Due date unavailable
TP-LINK's TL-WR843ND Wireless AP/Client Router is specially designed for Wireless ISP users, enabling wireless access to the Internet in areas with no wired ISP infrastructure (such as cable or xDSL). With up to 300Mbps wireless speed, it is ideal for interruption sensitive applications like HD video streaming.
TL-WR843ND can also serve as a normal wireless router, just like TL-WR841ND does. What's more, it supports Passive Power over Ethernet, convenient for deployment in areas without power outlets, such as a backyard or an attic.
Client Router Mode - WISP Client
TP-LINK's TL-WR843ND is designed to be set in Client Router mode as its default wireless mode to support a WISP connection. When it works as a WISP client device to access the Internet, local computers can connect to TL-WR843ND via wireless or cables.
300Mbps Wireless N - Speed & Range
With transmission rates up to 300Mbps, users can run bandwidth intensive devices including VoIP, HD streaming, or online gaming, without the lag. Using its powerful N technologies, the router is also able to mitigate data loss over long distances and through obstacles.
Passive PoE Support - Flexible Deployment
The TL-WR843ND is equipped with a RJ-45 WAN port, which is designed to support Passive PoE. For users that require a better WISP signal and need to place the device at location without power outlets, such as an attic or garage, the TL-WR843ND will fit the bill flawlessly with up to 30 meters Power over Ethernet capability. Users can easily have the most flexible deployment and don't have to be tethered to any outlets!
WPS Button - One Button Setup Security
The TL-WR843ND features Wi-Fi Protected Setup™ (WPS) that allows users to almost instantly setup their security simply by pressing the "WPS" button automatically establishing a WPA2 secure connection, which is more security compared with WEP encryptions. Not only is this faster than normal security setups but more convenient in that you don't need to remember a password!
Header / Product Line
TP-LINK
Header / Model
TL-WR843ND
Networking / Wireless Protocol
802.11b/g/n
Wireless router
Speed
300 Mbps
Networking / Connectivity Technology
Wired, Wireless
Header / Packaged Quantity
1
Networking / WAN Ports Qty
1
Miscellaneous / Encryption Algorithm
128-bit WEP, 152-bit WEP, 64-bit WEP, WPA, WPA-PSK, WPA2, WPA2-PSK
Networking / Integrated Switch
4-port switch
System Requirements / OS Required
Apple MacOS, Linux, Microsoft Windows 98SE/2000/NT/ME/XP/Vista/7, Novell NetWare, UNIX
Networking / Form Factor (FE)
Desktop
Standards
Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Networking / Network / Transport Protocol
IPSec, L2TP, PPPoE, PPTP
Header / Compatibility
Mac, PC
Networking / Routing Protocol
Static IP routing
Dimensions & Weight / Height
3.3 cm
Dimensions & Weight / Width
19.2 cm
Dimensions & Weight / Depth
13 cm
Accessories
£3.69
£12.63
C2G 2m Cat6a Shielded Patch - Blue
Quicklinx: 8H10 | In Stock
£7.76
£49.24
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
4* Ignore the quick setup and you will be fine
Reviewed by Tony on 06/06/2015
Device is sold as either a wireless repeater for picking up ISP (not internal) wireless signal or as a router. But if you put it in router mode but don't connect to the WAN port it will operate quite happily as a standard wired access point. Had it installed a few days and the coverage is good and good speed once connected. Good value for money and host of features which are (unfortunately) badly described. Probably not the best device if you are a network novice.
Scroll to top
