BT.com
Wishlist
TP LINK 300Mbps High Power Wireless USB Adapter
Delivery
Standard Due date unavailable
TP-LINK TL-WN8200ND is a 300 Mbps high power wireless adapter that allows users to enable their PCs or notebooks with extremely powerful wireless capability to deliver performance enhancements. The adapter adopts high power design which offers up to 10 times the range of conventional adapters. One of the TL-WN8200ND's best features is its stronger penetrability, which can effectively ensure that signal still remains reliable when it passes through multiple walls or floors.
TP-LINK TL-WN8200ND - network adapter
Network adapter
External
Interface (Bus) Type
USB
9.08 cm x 6.07 cm x 2.4 cm
802.11b, 802.11g, 802.11n
Data Transfer Rate
300 Mbps
Frequency Band
2.4 GHz
IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits)
Network adapter
External
USB
Wireless
Data Transfer Rate
300 Mbps
Frequency Band
2.4 GHz
Ad-Hoc Mode, Wi-Fi Protected Setup (WPS)
Aerial
Antenna
External detachable
Antenna Qty
2
Directivity
Omni-directional
Gain Level
5 dBi
2 x aerial - RP-SMA
1 x USB - mini-USB Type B
1 x USB cable ( external ) - 1.5 m
Encryption Algorithm
128-bit WEP, 64-bit WEP, WPA, WPA2, WPA-PSK, WPA2-PSK
Software Included
Drivers & Utilities
9.08 cm
6.07 cm
2.4 cm
10 - 90% (non-condensing)
Scroll to top
