BT.com
Wishlist
TP LINK 300Mbps AV500 WiFi Powerline Extender
Sale Price! - Was £39.99
Delivery
Standard 3-5 working days
TP-LINK's TL-WPA4220 extends your Internet connection to every room of the house through your home's existing electrical circuitry. The TL-WPA4220 features a Wi-Fi Clone Button enabling Super Range Extension, which means it can automatically copy the SSID and Password of your router. In this way, TL-WPA4220 simplifies your Wi-Fi configuration and allows for seamless roaming within your home network.
One Touch Super Range Extension
With a Wi-Fi Clone Button enabling Super Range Extension, the TL-WPA4220 can automatically copy the wireless network name (SSID) and Password of your router at the push of a button. After the pressing the button, you can place the powerline adapter anywhere you want wired or wireless access and enjoy seamless networking across your entire home or office.
Up to 500Mbps - Ideal for HD Video Streaming
With advanced HomePlug AV technology, TL-WPA4220 provides you with stable, high-speed data transfer rates of up to 500Mbps on a line length of up to 300 meters. It is a great choice for a whole home solution to connect all network compatible devices--from computers, game consoles to set-top boxes for IPTV to printers and NAS hard drives.
Extend WiFi Coverage to Every Room
With wireless speeds of up to 300Mbps, you can effortlessly extend your WiFi network via the existing powerline and broadcast a wireless signal to share with all your WiFi enabled devices in another area of your home or office.
Plug and Play
You can set up a hassle-free Powerline network within minutes with TP-LINK's powerline adapters, just plug in and play. Also, the adapters' "Pair" buttons can be utilized for securing or managing multiple powerline adapters in your home powerline network.
1. Plug one Internet connected adapter into a nearby power outlet.
2. Connect additional adapters to PCs/laptops/Internet TVs or other networked devices via an Ethernet cable or Wi-Fi - and you're done!
*Recommended: Press the pair buttons for network security and data encryption.
TP-LINK TL-WPA4220 - bridge - 802.11b/g/n - wall-pluggable
Bridge
Enclosure Type
Wall-pluggable
Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, HomePlug AV (HPAV)
Data Transfer Rate
300 Mbps
IEEE 802.3, IEEE 802.3u, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, HomePlug AV
9.4 cm x 5.4 cm x 4 cm
Apple MacOS, Linux, Microsoft Windows 2000, Microsoft Windows XP, Microsoft Windows Server 2003, Microsoft Windows 7, Microsoft Windows Vista, Windows 8
Bridge
Enclosure Type
Wall-pluggable
Wireless, wired
Data Transfer Rate
300 Mbps
Encryption Algorithm
WPA, WPA2, WPA-PSK, 128-bit AES, WPA2-PSK, WEP
IEEE 802.3, IEEE 802.3u, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, HomePlug AV, Plug and Play, FCC, RoHS
Status Indicators
Power, link/activity
Line Properties
Line Coding Format
OFDM
1 x HomePlug AV , 2 x 10Base-T/100Base-TX - RJ-45
1 x network cable - 2 m
9.4 cm
5.4 cm
4 cm
10 - 90% (non-condensing)
Accessories
£4.95
£3.84
£11.67
C2G 2m Cat6a Shielded Patch - Blue
Quicklinx: 8H10 | In Stock
£8.42
£52.93
Scroll to top
