BT.com
Wishlist
TP LINK 24-Port Gigabit L2 Managed Switch with 4 Combo SFP Slots
Delivery
Standard Due date unavailable
TP-LINK JetStream gigabit L2 managed switch TL-SG3424 provides 24 10/100/1000 Mbps ports. The switch provides high performance, enterprise-level QoS, advanced security strategies and rich layer 2 management features. Moreover, the switch also comes equipped with 4 combo SFP slots, expanding your network flexibly. This JetStream gigabit L2 managed switch is cost-effective for the ideal small and medium business solution.
TL-SG3424 has robust security and management features. The IP-MAC-Port-VID Binding and Access Control List (ACL) functions protect against broadcast storm, ARP and Denial-of-Service (DoS) attacks, etc. Quality of Service (QoS, L2 to L4) provides enhanced traffic management capabilities to move your data smoother and faster. Anymore, the easy-to-use web management interfaces, along with CLI, SNMP and RMON, mean faster setup and configuration with less downtime. For workgroup and departments requiring cost-sensitive Layer 2 switch and gigabit capability, TP-LINK JetStream L2 managed Switch TL-SG3424 provides you the ideal access-edge solution.
TP-LINK JetStream TL-SG3424 - switch - 24 ports - Managed - rack-mountable
Switch - 24 ports - Managed
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
24 x 10/100/1000 + 4 x combo Gigabit SFP
Performance
Switching capacity: 48 Gbps
MAC Address Table Size
8K entries
Jumbo Frame Support
10240 bytes
Routing Protocol
IGMP
Remote Management Protocol
SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, Telnet, SNMP 3, SNMP 2c, HTTPS, SSH, SSH-2, CLI
Flow control, Layer 2 switching, DHCP support, ARP support, VLAN support, IGMP snooping, DoS attack prevention, port mirroring, half duplex mode, full duplex mode, Spanning Tree Protocol (STP) support, Rapid Spanning Tree Protocol (RSTP) support, Multiple Spanning Tree Protocol (MSTP) support, DHCP snooping, Access Control List (ACL) support, Quality of Service (QoS), RADIUS support, SSH support, LACP support, Link Aggregation Control Protocol (LACP), IP-MAC binding
IEEE 802.3u, IEEE 802.3i, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.1v
44 cm x 22 cm x 4.4 cm
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
Performance
8K entries
Jumbo Frame Support
10240 bytes
Routing Protocol
IGMP
Encryption Algorithm
TLS 1.0, SSL 3.0, SSL 2.0
Authentication Method
Secure Shell (SSH), RADIUS
Status Indicators
Power, system, link/activity
24 x 1000Base-T RJ-45 , 4 x Ethernet 1000 - SFP (mini-GBIC) , 1 x console RJ-45 management
Internal power supply
4 rubber feet
Rack Mounting Kit
Included
FCC
Software Included
Drivers & Utilities
44 cm
22 cm
4.4 cm
10 - 90% (non-condensing)
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
Humidity Range Storage
5 - 90% (non-condensing)
Accessories
£3.74
£13.46
C2G 2m Cat6a Shielded Patch - Blue
Quicklinx: 8H10 | In Stock
£8.26
£52.42
Scroll to top
