BT.com
Wishlist
TP LINK 2.4GHz High Power Wireless Outdoor Access Point
Delivery
Standard Due date unavailable
The TL-WA5210G 2.4 GHz High Power Wireless Outdoor CPE is dedicated to WISP CPE solution and long distance wireless network solutions. It integrates the functions of a Wireless Access Point, WISP Client, high gain antenna and weatherproof enclosure. It features 12 dBi high gain antenna, high output power and high RX sensitivity can significantly extend the transmission range to deliver a more stable wireless connection. Complies with IEEE 802.11 b/g, TL-WA5210G creates an wireless network up to 54 Mbps, making it great for Internet surfing and files exchange.
TP-LINK TL-WA5210G - radio access point
Radio access point
External
Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g
Frequency Band
2.4 GHz
PoE injector
UNIX, Apple MacOS, Novell NetWare, Microsoft Windows 98 Second Edition, Linux, Microsoft Windows Vista / XP / 7, Microsoft Windows 2000 / NT
Power Over Ethernet (PoE) Supported
PoE
26.5 cm x 12 cm x 8.3 cm
Radio access point
26.5 cm
12 cm
8.3 cm
External
Wireless
Data Transfer Rate
54 Mbps
Frequency Band
2.4 GHz
Max Range Open Space
15 km
WISP mode, weather proof
Encryption Algorithm
AES, 128-bit WEP, 64-bit WEP, 152-bit WEP, TKIP, WPA, WPA2, WPA-PSK, WPA2-PSK
Aerial
Directivity
Directional
Gain Level
12 dBi
PoE injector
FCC, RoHS
PoE
External power adapter
Software Included
Drivers & Utilities
-30 °C
70 °C
10 - 70%
Accessories
£5.12
£3.87
£12.34
C2G 2m Cat6a Shielded Patch - Blue
Quicklinx: 8H10 | In Stock
£8.82
C2G TruLink Media Gateway RJ45 Cap
Quicklinx: 8Q37 | In Stock
£0.69
£55.96
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
5* Easy to set up - works great!
Reviewed by Anonymous on 07/12/2013
This unit has both a quick setup and the more advanced setup configurations available. Both work well, as I used the quick setup to test my setup then went into the advanced config to add wireless security and AP isolation. The TP-Link is mounted to a metal pole 12 feet high and the signal rocks some 2500 feet away over fairly level ground (high desert). I have good consistent throughput from the TP-Link with the distance setting at 2km, it's advertised to work at much greater distances that that. Although I chose to use a similar unit to receive the WiFi signal broadcast by the TP-Link (for my particular network needs), both of our laptops had no problem in connecting directly to the TP-Link without the receiver. I've not had to reset or reboot the unit in the two weeks I've had the unit installed.
The only negative about the unit is that the Cat5 cable included to connect the TP-Link to the power insertion device is quite short so plan on purchasing a longer cable to complete your installation.
Scroll to top
