BT.com
Wishlist
TP LINK 150Mbps Wireless N Router, internal antenna, 2 LAN ports
Delivery
Standard Due date unavailable
The TL-WR720N is a simple and secure way to share your high-speed Internet connection at Wireless-N speeds for surfing the Internet, email or online chat.
The wireless N Router is 802.11b & g compatible and gives users 802.11n performance up to 150Mbps at a remarkably affordable price. Bordering on 11n and surpassing 11g speed enables bandwidth-intensive applications such as video streaming. Users can enjoy a high quality experience when video streaming, using VoIP, or gaming online wirelessly, not previously practical with 11g devices.
Exceptional Wireless Performance at an Affordable Price
TP-LINK's TL-WR720N is a high speed solution that is compatible with IEEE 802.11b/g/n. Based on 802.11n technology, TL-WR720N gives users wireless performance at up to 150Mbps, 9X the speed and 4x the range of traditional 11g products. Enjoy N Power at a G Price!
Multi-SSID Networking - Simple and Secure Wireless Sharing
TL-WR720N supports up to 4 SSIDs. It's uniquely designed for users to set up additional wireless networks with additional SSIDs and Passwords for guests or friends. This ensures users are safe and there are no performance conflicts with different networks.
CCA Technology - Stable Wireless Signals
Clear Channel Assessment (CCA) automatically avoids channel conflicts using its clear channel selection feature and fully realizes the advantages of channel binding, greatly enhancing wireless performance. IP QoS -- Manage your Bandwidth
Within the wireless network, indiscriminate Internet surfing and bandwidth-guzzling downloads by internal users often leave homes or small offices with insufficient bandwidth. TL-WR720N supports an IP QoS function, allowing optimum utilization of bandwidth and offering bandwidth control over congestion, preventing bandwidth abuse. In this way, users of a small network receive committed and specific bandwidth, preventing non-critical applications from degrading network performance.
Easy to Use
With the TL-WR720N even novice users can setup their networks. The device comes with a CD featuring an Easy Setup Assistant that leads users through the setup process step-by-step, and even helps with wireless network settings and security configurations.
Wireless router - 2-port switch (integrated)
Enclosure Type
Desktop
Wireless, wired
Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Frequency Band
2.4 GHz
Data Transfer Rate
150 Mbps
Network / Transport Protocol
PPTP, L2TP, IPSec, PPPoE, DHCP
Routing Protocol
Static IP routing
Encryption Algorithm
128-bit WEP, 64-bit WEP, 152-bit WEP, WPA, WPA2, WPA-PSK, WPA2-PSK
Firewall protection, DMZ port, DHCP support, Stateful Packet Inspection (SPI), DoS attack prevention, dynamic DNS server, manageable, MAC address filtering, Wireless Distribution System (WDS) support, parental control, IP address filtering, Wi-Fi Multimedia (WMM) support, Quality of Service (QoS), Wi-Fi Protected Setup (WPS), Multiple SSID support, wireless bridge mode, bandwidth control, port triggering, IP-MAC binding
IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, UPnP, FCC, RoHS
LAN: 2 x 10Base-T/100Base-TX - RJ-45 , WAN: 1 x 10Base-T/100Base-TX - RJ-45
Aerial
Aerial
Internal
External power adapter
1 x network cable
UNIX, Apple MacOS, Novell NetWare, Linux, Microsoft Windows 2000/XP/Vista/7
15.8 cm
12.2 cm
3.2 cm
10 - 90%
Scroll to top
