BT.com
Wishlist
TP LINK 150Mbps wireless N Nano USB adapter
TP LINK 150Mbps wireless N Nano USB...
£7.53
£7.53
Add to wishlist
Delivery
Standard 1-3 working days
Express Delivered on Tuesday
Express Delivery
  • 00 h
  • 00 m
  • 00 s
TP-LINK's 150Mbps wireless N Nano USB adapter, TL-WN725N allows users to connect a desktop or notebook computer to a wireless network at 150Mbps. This miniature adapter is designed to be as convenient as possible and once connected to a computer's USB port, can be left there, whether traveling or at home. It also features advanced wireless encryption and easy installation.
Miniature Design - Plug in and forget
With its miniature size and sleek design, users can connect the nano adapter to any USB port and leave it there. There's no need to worry about blocking adjacent USB interfaces or that the adapter may fall out when moving a connected laptop from A to B, with the tiny device flush against the USB port.
150Mbps Wireless N Speed - Stable Wireless Signals
The TL-WN725N complies with wireless 802.11 b/g/n standards, with transmission data rates of up to 150Mbps enabling fast wireless connections for lag-free online gaming and video streaming.
WPA / WPA2 Encryptions - Advanced Security
When speaking about wireless security, WEP encryptions are no longer the strongest and safest protections against intrusions. The TL-WN725N provides WPA/WPA2 encryptions created by the WI-FI Alliance™, promoting interoperability and security for WLAN, which effectively and efficiently protects users' wireless networks.
Bundled CD for Easy Operation
The TL-WN725N comes with a 14-language utility located on its bundled CD that helps users complete the software installation and wireless network settings, including security configurations and wireless connections, quickly and easily, even for novice users new to wireless networking.
TP-LINK TL-WN725N Nano Wireless USB Adapter - network adapter
Network adapter
External
Interface (Bus) Type
Hi-Speed USB
1.86 cm x 1.5 cm x 0.71 cm
2.1 g
IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Data Transfer Rate
150 Mbps
Frequency Band
2.4 GHz
IEEE 802.11b, IEEE 802.11g, IEEE 802.1x, USB 2.0, IEEE 802.11n
Microsoft Windows Vista / XP / 7, Microsoft Windows Vista / XP / 7 (64-bit versions)
2 years warranty
Network adapter
External
Hi-Speed USB
1.86 cm
1.5 cm
0.71 cm
2.1 g
Wireless
Spread Spectrum Method
OFDM
Data Transfer Rate
150 Mbps
Line Coding Format
DBPSK, DQPSK, CCK, 64 QAM, 16 QAM, OFDM
Frequency Band
2.4 GHz
Software access point, Wi-Fi Multimedia (WMM) support, Ad-Hoc Mode
Aerial
Antenna
Internal integrated
1 x Hi-Speed USB - 4 PIN USB Type A
Encryption Algorithm
AES, 128-bit WEP, 64-bit WEP, TKIP, WPA, WPA2, WPA-PSK, WPA2-PSK
IC, FCC, RoHS
2 years warranty
Service & Support Details
10 - 90% (non-condensing)
Other bundles
£7.53
Save on Intenso 32GB USB Drive
Save £1.48
£12.03
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
5* Not Yet made a purchase
Reviewed by Anonymous on 12/10/2014
Have not yet purchased anything.
Scroll to top
