BT.com
Wishlist
TP LINK 150Mbps Wireless N Nano Router
Delivery
Standard Due date unavailable
The TL-WR702N is designed for use with tablets, smart phones, handheld game consoles and other portable electronic wireless devices. The device, which can be powered by an external power adapter or USB connection to a computer, can conveniently connect to the internet and share the connection around an average sized room at 150Mbps.The device's tiny size makes it ideal for use on the road and is powerful enough to satisfy almost any basic wireless application requirement.
Portable and Compact--Ideal for Home and Travel Use
TL-WR702N is the smallest wireless router in the world and very easy to use. A traveler need simply plug a hotel room's WAN cable into the port provided and enter a default password to instantly create a wireless hotspot in the room.
Flexible Power Supply--Easy to Take on the Road
TL-WR702N has a Micro USB port and can be powered by an external power adapter or via a USB connection to a computer. When traveling, users can plug the TL-WR702N into their computer's USB port and share their Wi-Fi connection with family and friends.
Multiple Operating Modes
TL-WR702N supports AP, Router, Bridge, Client and Repeater modes to enable various wireless applications to give users a more dynamic and comprehensive wireless networking experience.
Advanced Security
TL-WR702N provides WPA-PSK/WPA2-PSK encryptions, which can effectively and efficiently protect the wireless network. What makes the nano router more powerful is its Pre-Encryption function which sets the initial SSID and Password for users to protect their wireless security.
TP-LINK TL-WR702N - wireless router - 802.11b/g/n - desktop
Wireless router
Enclosure Type
Desktop
WAN Ports Qty
1
Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Frequency Band
2.4 GHz
Data Transfer Rate
150 Mbps
Network / Transport Protocol
PPTP, L2TP, IPSec, PPPoE, DHCP
Routing Protocol
Static IP routing
Firewall protection, DMZ port, DHCP support, repeating mode, Stateful Packet Inspection (SPI), DoS attack prevention, MAC address filtering, URL filtering, IP address filtering, Access Point operational mode, Wi-Fi Multimedia (WMM) support, Access Control List (ACL) support, virtual server support, port triggering
IEEE 802.3, IEEE 802.3u, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, UPnP
5.7 cm x 5.7 cm x 1.8 cm
Wireless router
Enclosure Type
Desktop
Wireless, wired
Frequency Band
2.4 GHz
Data Transfer Rate
150 Mbps
Routing Protocol
Static IP routing
Encryption Algorithm
128-bit WEP, 64-bit WEP, 152-bit WEP, WPA, WPA2, WPA-PSK, WPA2-PSK
IEEE 802.3, IEEE 802.3u, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, UPnP, FCC, RoHS
WAN / LAN: 1 x 10Base-T/100Base-TX - RJ-45 , USB 2.0: 1 x
Aerial
Aerial
Internal
External power adapter
1 x USB cable , 1 x network cable
Software Included
Drivers & Utilities
5.7 cm
5.7 cm
1.8 cm
10 - 90% (non-condensing)
Accessories
£4.95
£3.84
£11.73
C2G 2m Cat6a Shielded Patch - Blue
Quicklinx: 8H10 | In Stock
£8.31
£53.25
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
5* TP LINK 150Mbps Wireless N Nano Router
Reviewed by Anonymous on 20/03/2014
best thing since sliced bread at this price point.. set up slightly fiddly but plenty of help on the web.. Bought to connect my set top box with my BT home hub in client mode.. works a treat..
1* Does not work with BT infinity
Reviewed by Anonymous on 19/12/2014
BT had to reset my wireless and destroyed this product. It no longer works with BT, and even a replacement has failed to work. DO NOT BUY THIS PRODUCT, BT WILL RUIN IT
Scroll to top
