BT.com
Wishlist
TP LINK 150Mbps Portable 3G Wireless N Router
TP LINK 150Mbps Portable 3G...
£27.78
£27.78
Add to wishlist
Delivery
Standard Due date unavailable
What make this router outstanding are its travel-size design and Mini USB Port, which can be connected to a laptop or power adapter to be used as a power supply. As long as you have your laptop, the TL-MR3020 can be powered and a wireless cloud is created that can be shared by iPads, iTouches, Android Phones, Kindles and the vast majority of other portable Wi-Fi enabled devices.
Compatibility is the most important aspect to consider when you're selecting a 3G router. TP-LINK has made certain that 3G routers are compatible with the ISPs in the regions in which they are sold.
With one button security setup, the TL-MR3020 allows users to instantly setup their security simply by pressing the WPS button on the router and automatically establishing a WPA2 secure connection, which is more secure when compared with WEP encryptions. Not only is this faster and safer than normal security setups but more convenient in that users needn't remember a password!
Bandwidth of mobile broadband is limited. With the router's IP QoS function, the TL-MR3020 allows optimum utilization of bandwidth and offers bandwidth control over congestion, preventing bandwidth abuse. When sharing your mobile broadband with others, you can decide how the bandwidth is shared based on your requirements.
The TL-MR3020 can be installed quickly and easily almost anywhere. All you need to do is insert the USB modem into the router, search for its wireless SSID on your computer and connect to it. Users can be online and surfing the Internet in no time, with the user guide on provided CD, even novice users can easily set up their wireless Internet connections.
What's in the box
  • TP-LINK TL-MR3020
  • USB cable
  • Network cable
  • Software
TP-Link TL-MR3020 - wireless router - 802.11b/g/n - desktop
Wireless router
Enclosure Type
Desktop
WAN Ports Qty
1
Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Frequency Band
2.4 GHz
Data Transfer Rate
150 Mbps
Firewall protection, DMZ port, DHCP support, DoS attack prevention, MAC address filtering, parental control, Access Point operational mode, WISP mode, virtual server support, 3G/3.75G USB Dongle Support, port triggering
IEEE 802.3, IEEE 802.3u, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, UPnP
7.4 cm x 6.7 cm x 2.2 cm
Wireless router
Enclosure Type
Desktop
Wireless, wired
Frequency Band
2.4 GHz
Data Transfer Rate
150 Mbps
Encryption Algorithm
128-bit WEP, 64-bit WEP, WPA-PSK, WPA2-PSK
IEEE 802.3, IEEE 802.3u, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, UPnP, FCC, RoHS
WAN / LAN: 1 x 10Base-T/100Base-TX - RJ-45 , USB 2.0: 1 x 4 pin USB Type A
External power adapter
1 x USB cable , 1 x network cable
Software Included
Drivers & Utilities
7.4 cm
6.7 cm
2.2 cm
-10 °C
60 °C
10 - 90% (non-condensing)
Accessories
Network Adaptors
Expand your network
£28.21
Other bundles
C2G 2m USB 2.0 A/B Cable - Black
Quicklinx: 63M8 | In Stock
£3.72
C2G 5m USB 2.0 A/B Cable - Black
Quicklinx: 63MW | In Stock
£5.43
£15.39
C2G 4-Port USB 2.0 Aluminum Hub
Quicklinx: 7BB4 | In Stock
£23.18
C2G 12m USB 2.0 A/A Active Extension Cable
Quicklinx: 7BB8 | In Stock
£20.19
C2G USB Superbooster Extender Kit
Quicklinx: 7H7B | In Stock
£45.61
£50.76
Scroll to top
