BT.com
Wishlist
TP LINK 150Mbps Mini Wireless N USB Adapter
Delivery
Standard Due date unavailable
TP-LINK's Mini Wireless N USB Adapter, TL-WN723N allows users to connect a desktop or notebook computer to a wireless network and access a high-speed Internet connection. The TL-WN723N is designed to be as convenient for users as possible, so there's no need to worry that one USB interface will be blocked by its neighbor with the adapter being so small. A device the size of a fingertip designed to keep the workspace neat and tidy.
150Mbps Wireless N Speed - Stable Wireless Signals
The TL-WN723N complies with wireless 802.11 b/g/n standards, with transmission data rates of up to 150Mbps enabling fast wireless connections for lag-free online gaming and video streaming. What's more, users can easily pick up wireless network coverage at further distances where legacy 11g products may not!
Clear Channel Assessment (CCA) automatically avoids channel conflicts using its clear channel selection feature that makes sure that in crowded environments such as apartment or office buildings, that users will be using the channel most free of traffic.
One Button Security Setup
Compatible with WI-FI Protected Setup™ (WPS), TL-WN723N features Quick Security Setup that allows users to almost instantly setup their security simply by pressing the "QSS" button, automatically establishing a WPA2 secure connection. Not only is this faster than normal security setups but more convenient in that users don't need to remember a password!
WPA / WPA2 Encryptions - Advanced Security
When speaking about WI-Fi security, WEP encryptions are no longer the strongest and safest protections against intrusions. The TL-WN723N provides WPA/WPA2 encryptions created by the WI-FI Alliance, promoting interoperability and security for WLAN, which effectively and efficiently protects the wireless network.
Bundled CD for Easy Operation
The TL-WN723N comes with a utility located on its bundled CD that helps users complete the software installation and wireless network settings, including security configurations and wireless connections, quickly and easily, even for novice users new to wireless networks.
TP-LINK TL-WN723N - network adapter
Network adapter
External
Interface (Bus) Type
USB 2.0
3.7 cm x 1.7 cm x 0.8 cm
802.11b, 802.11g, 802.11n
Data Transfer Rate
150 Mbps
Frequency Band
2.4 GHz
IEEE 802.11b, IEEE 802.11g, IEEE 802.1x, IEEE 802.11n
Microsoft Windows 2000, Microsoft Windows XP, Microsoft Windows XP 64-bit Edition, Microsoft Windows 7, Microsoft Windows 7 64-bit Edition, Microsoft Windows Vista (32/64 bits)
Network adapter
External
USB 2.0
Wireless
Data Transfer Rate
150 Mbps
Line Coding Format
DBPSK, DQPSK, CCK, 64 QAM, 16 QAM, OFDM
Frequency Band
2.4 GHz
MAC address filtering, Ad-Hoc Mode, Wi-Fi Protected Setup (WPS)
Aerial
Antenna
Internal
1 x USB 2.0 - 4 pin USB Type A
Encryption Algorithm
AES, 128-bit WEP, 64-bit WEP, TKIP, WPA, WPA2, WPA-PSK, WPA2-PSK
FCC, RoHS
3.7 cm
1.7 cm
0.8 cm
10 - 95% (non-condensing)
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
1* Avoid at all costs
Reviewed by Anonymous on 13/11/2012
It works for a while but regularly loses connection and forgets the wireless key - cheap and not at all reliable
Scroll to top
