BT.com
Wishlist
Toshiba USB3.0 to Gigabit LAN Adapter
Delivery
Standard Due date unavailable
The Toshiba USB 3.0 to Gigabit Ethernet Adapter lets you add one RJ-45 Ethernet port to your USB-enabled laptop or desktop computer quickly and easily. Simply plug into a USB 3.0 port and enjoy data transfer rates of up to 1000 Mbps over your Gigabit network.
This compact adapter is USB 3.0 compliance and backward compatible with USB 2.0 or earlier version. It is an ideal network solution for both home and business environment and a great alternative for a gaming console that required network access but without Wi-Fi. It is USB bus-powered and does not require power adapter.
Toshiba USB 3.0 Gigabit Ethernet Adapter - network adapter
Network adapter
External
Interface (Bus) Type
SuperSpeed USB 3.0
Ports
Gigabit Ethernet
2.1 cm x 7.44 cm x 1.6 cm
46.4 g
10Mb LAN, 100Mb LAN, GigE
Data Transfer Rate
1 Gbps
Microsoft Windows XP, Microsoft Windows 7, Windows 8
1 year warranty
KIRA 10, 108; Portégé A30, Z20T, Z30, Z30t; Satellite C40; Satellite Pro A30, A40, A50, R40, R50; Satellite Radius 11; 12; 14; 15; Tecra A40, A50, Z40, Z50
Network adapter
External
SuperSpeed USB 3.0
Ports
Gigabit Ethernet
Wired
Data Transfer Rate
1 Gbps
USB powered
1 x 1000Base-T - RJ-45
1 x SuperSpeed USB cable (integrated)
Software Included
Driver
2.1 cm
7.44 cm
1.6 cm
46.4 g
Limited warranty - 1 year
Toshiba KIRA 108, 10H, 10J, 10Q , Toshiba Portégé A30-C-14R, A30-C-14U, A30-C-14X, A30-C-180, A30-C-1HE, A30-C-1HF, Z20T-B-11K, Z20t-C-11E, Z20t-C-11H, Z20t-C-11Q, Z20t-C-121, Z20t-C-12F, Z20t-C-12R, Z20t-C-13Z, Z20t-C-155, Z30-B-12J, Z30-C-10N, Z30-C-10W, Z30-C-10Z, Z30-C-125, Z30-C-12U, Z30-C-138, Z30-C-13H, Z30-C-16J, Z30-C-16L, Z30-C-16N, Z30-C-193, Z30t-C-110, Z30t-C-139 , Toshiba Satellite C40-C-10T , Toshiba Satellite Pro A30-C-130, A30-C-14E, A30-C-182, A30-C-1EP, A30-C-1F3, A40-C-13U, A40-C-1D7, A50-C-12P, A50-C-12W, A50-C-1GL, A50-C-1GW, A50-C-1HF, A50-C-1HG, A50-C-1NC, A50-C-1ND, A50-C-1PR, A50-C-1TQ, A50-C-1U1, A50-C-207, A50-C-23P, A50-C-24W, R40-C-12H, R50-C-104, R50-C-14H, R50-C-14J, R50-C-15W, R50-C-179, R50-C-17C , Toshiba Satellite Radius 11 CL10W-B-100 , Toshiba Satellite Radius 12 P20W-C-103, P20W-C-104, P20W-C-10H, P20W-C-10K , Toshiba Satellite Radius 14 L40W-C-109, L40W-C-10H, L40W-C-10L, L40W-C-10R, L40W-C-10V, L40W-C-10X, L40W-C-10Z, L40W-C-115 , Toshiba Satellite Radius 15 P50W-C-102, P50W-C-106, P50W-C-10E, P50W-C-10J, P50W-C-10P, P50W-C-10V , Toshiba Tecra A40-C-147, A40-C-15X, A40-C-17C, A40-C-1E5, A40-C-1HT, A40-C-1KF, A50-C-1G0, A50-C-1H2, A50-C-1KC, A50-C-1QK, A50-C-1RL, A50-C-1U2, A50-C-1UG, A50-C-1V0, A50-C-1W2, A50-C-200, A50-C-218, Z40-C-10R, Z40-C-136, Z50-C-114, Z50-C-115, Z50-C-11J, Z50-C-11W, Z50-C-151
Scroll to top
