BT.com
Wishlist
Toshiba TransMemory 64GB Flash Drive USB 2.0 - White
Delivery
Standard 3-5 working days
This is a promotional product to be bundled with Microsoft Office Home & Business 2016 only - if you would like to buy this product separately please type BR0Y in the search bar at the top of this webpage
The USB 2.0 standard A Type has a size of 12 mm width and a height of 4.5 mm. Suitable in all USB 2.0 ports which is standard in every PC. Data transmission is possible in both directions.
Devices can be connected and detected during operation. Just plug and play and transfer your favorite music and images.
Low power consumption is achieved thanks to Toshiba's original technology, such as multi-layering of high-speed NAND flash memory and a dedicated low-power-consumption ASIC controller. As a result, power consumption of notebook PCs is minimized even when using a USB flash memory.
Toshiba TransMemory U202 - USB flash drive - 64 GB
USB flash drive
Interface Type
USB 2.0
Storage Capacity
64 GB
Enclosure Colour
White
Apple MacOS X 10.0.2 or later, Microsoft Windows 2000/XP/Vista/7/8
5 years warranty
USB flash drive
Storage Capacity
64 GB
Enclosure Colour
White
Compatibility
Non-specific
Read Rate
Up to 18 MB/s
Write Rate
Up to 5 MB/s
Interface Type
USB 2.0
Limited warranty - 5 years
21.4 mm
51.4 mm
8.4 mm
8 g
50 °C
20 - 95% (non-condensing)
Scroll to top
