BT.com
Wishlist
Toshiba Portege Z30-C-10Z i5-6300U 8GB 256SSD 13.3" Win 7 Pro/10 Pro
Delivery
Standard Due date unavailable
The Portégé Z30-C was made to move. Ultralight and highly robust, with a capacitive battery, it's the perfect companion to take on your business travels. And if you're out and about in direct sunlight, you won't see any glare on the non-reflective high-definition screen with LED backlighting. It's really convenient to type e-mails or create documents, in or out the office - even in dim conditions, using the illuminated keyboard. With its powerful processor, your laptop has all the power you need to multitask on the move or in the office. And with a high-performance drive inside, the Portégé Z30-C delivers faster speeds and higher responsiveness from the second you boot up to the minute you shut down. There's no compromise, so you can run all of your business applications with ease. The Portégé Z30-C is packed with mobile flexibility - and because all ports are full-size, you won't need any special adapters either. You can transfer data to other devices much faster, using USB 3.0 ports or share your presentations in high-resolution brilliance, with HDMI. Gigabit LAN also allows fast access to your local network, while support for LTE gives you the freedom to work wirelessly, so you can be more productive anywhere.
Toshiba Portégé Z30-C-10Z - 13.3" - Core i5 6300U - 8 GB RAM - 256 GB SSD
Ultrabook
Operating System
Win 7 Pro (downgrade from Windows 10 Pro) + Windows 10 Pro Licence
Intel Core i5 (6th Gen) 6300U / 2.4 GHz (3 GHz) / 3 MB Cache
8 GB DDR3L (1 x 8 GB)
Storage
256 GB SSD
Optical Drive
No optical drive
Display
13.3" LED backlight 1920 x 1080 / Full HD
Graphics
Intel HD Graphics 520
Input Device
DualPoint
Keyboard Backlight
Integrated Webcam
Bluetooth 4.0, 802.11a/b/g/n/ac, Gigabit Ethernet
4-cell - up to 14 hours
Dockable
Security
Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader, SmartCard reader
Steel gray metallic, matte black keyboard
31.6 cm x 22.7 cm x 1.79 cm
1.2 kg
United Kingdom
Environmental Standards
ENERGY STAR Qualified
International warranty - 1 year - carry-in
Ultrabook
Operating System
Microsoft Windows 7 Professional (available through downgrade rights from Windows 10 Pro) + Windows 10 Pro Licence
Processor / Chipset
CPU
Max Turbo Speed
3 GHz
Number of Cores
Dual-Core
Cache
L3 - 3 MB
64-bit Computing
Intel Turbo Boost Technology 2.0
RAM
8 GB (1 x 8 GB)
Max RAM Supported
16 GB
DDR3L SDRAM
Speed
1600 MHz
Slots Qty
2
Empty Slots
1
Storage
Main Storage
256 GB SSD SATA
Display
13.3"
LCD Backlight Technology
LED backlight
Resolution
1920 x 1080 (Full HD)
Widescreen
Image Aspect Ratio
16:9
HighBrightness, anti-reflective
Audio & Video
Graphics Processor
Camera
Yes - Full HD
Resolution
2 Megapixel
Sound
Stereo speakers, stereo microphone
High Definition Audio, DTS Studio Sound
Input
Keyboard, DualPoint
Keyboard Backlight
Multi-touch clickpad
Communications
Wireless
Wireless Controller
Intel Dual Band Wireless-AC 8260
Network Interface
Gigabit Ethernet
Intel Wireless Display (WiDi)
Wi-Fi CERTIFIED
4-cell lithium polymer
Run Time
Up to 14 hours
AC Adapter
Input
AC 120/230 V
Output
19 V, 2.37 A
Connections & Expansion
3 x USB 3.0 , HDMI , VGA , Headphone/microphone combo jack , LAN , Dock
Memory Card Reader
Yes (SD Card, MultiMediaCard, SDHC Card, SDXC Card)
Software
Software Included
Toshiba PC Health Monitor, Toshiba Eco Utility, Microsoft Office 365 (30 days trial), DTS Studio Sound, McAfee LiveSafe (30 days subscription), Windows 10 Pro (DVD)
Case Material
Magnesium alloy
Dockable
Security
Security lock slot (cable lock sold separately), administrator password, system password, hard drive password, USB Sleep-and-charge ports
Power adapter
Localization
United Kingdom
1.2 kg
ENERGY STAR Certified
Accessories
£9.99
£7.28
C2G 5m Select High Speed HDMI with Ethernet
Quicklinx: 915L | In Stock
£19.86
£39.09
£52.42
C2G Pro HDMI to VGA Converter
Quicklinx: 9N1C | In Stock
£59.47
£17.48
Scroll to top
