BT.com
Wishlist
Toshiba Hi-Speed Port Replicator
Delivery
Standard Due date unavailable
With the ability to attach up to six USB devices simultaneously, together with HDMI, Display and GigaLAN Fast Ethernet ports, Toshiba's Hi Speed Port Replicator III delivers comprehensive connectivity and lightning-fast performance to your laptop - with no cables in sight. Simply plug in your machine and enjoy immediate access to all your peripherals, from printers, storage and screens to keyboards, mice and power sources. It's the perfect way to stay productive while keeping your workspace the way you want it.
Toshiba Hi Speed Port Replicator III - port replicator
Port replicator
38.09 cm x 14.9 cm x 3.15 cm
720 g
EMEA
Power adapter - external 120 Watt
Portégé A30, A30t, R30, Z30, Z30 4G/SSD-1EL, Z30T, Z40; Satellite Pro A30; Tecra A40, A50, Z40, Z50, Z50 SSHD-15
Port replicator
38.09 cm
14.9 cm
3.15 cm
720 g
Enclosure Colour
EMEA
4 x SuperSpeed USB 3.0 - 9 pin USB Type A , 2 x USB 2.0 - 4 pin USB Type A , 1 x display / video - DVI-Digital - 24+1 pin digital DVI , 1 x display / video - HDMI - 19 pin HDMI Type A , 1 x display / video - VGA - 15 pin HD D-Sub (HD-15) , 1 x network - 10Base-T/100Base-TX/1000Base-T - RJ-45 , 1 x microphone - input - mini-phone 3.5 mm , 1 x audio - output - mini-phone stereo 3.5 mm , 1 x display / video - DisplayPort - 20 pin DisplayPort
Power Provided
120 Watt
Microsoft Windows 7 (32/64 bits), Windows 8
Toshiba Portégé A30-C-113, A30-C-148, A30-C-14J, A30-C-14P, A30-C-14R, A30-C-14U, A30-C-14X, A30-C-180, A30-C-1CX, A30-C-1CZ, A30-C-1D7, A30-C-1DN, A30-C-1DP, A30-C-1DQ, A30-C-1DT, A30-C-1H2, A30-D-114, A30t-C-11U, R30-A-18P, R30-A-19V, R30-A-1FL, Z30-A-14Z, Z30-B-00W, Z30-B-10M, Z30-B-10Q, Z30-B-10V, Z30-B-112, Z30-B-117, Z30-B-11G, Z30-B-11R, Z30-B-11V, Z30-B-11W, Z30-B-120, Z30-B-12E, Z30-B-12F, Z30-B-12J, Z30-B-12K, Z30-B-14E, Z30-B-14F, Z30-B-14R, Z30-B-14U, Z30-B-14W, Z30-B-14X, Z30-B-14Z, Z30-B-15H, Z30-B-15J, Z30-B-15L, Z30-C-10V, Z30-C-122, Z30-C-124, Z30-C-12K, Z30-C-12Z, Z30-C-13H, Z30-C-16H, Z30-C-16J, Z30-C-16L, Z30-C-16M, Z30-C-16N, Z30-C-170, Z30-C-176, Z30-C-177, Z30-C-178, Z30-C-18X, Z30t-A-12J, Z30t-B-104, Z30t-B-10L, Z30t-B-10V, Z30t-C-110, Z30t-C-119, Z30t-C-11R, Z30t-C-127, Z30t-C-133, Z30t-C-136, Z40-C-103 , Toshiba Satellite Pro A30-C-1D0 , Toshiba Tecra A40-C-13Z, A40-C-140, A40-C-141, A40-C-142, A40-C-147, A40-C-14L, A40-C-14U, A40-C-14V, A40-C-15X, A40-C-17C, A40-C-1C2, A40-C-1HN, A40-C-1KE, A50-C-16E, A50-C-16F, A50-C-16G, A50-C-16H, A50-C-16J, A50-C-16K, A50-C-16L, A50-C-16U, A50-C-179, A50-C-19L, A50-C-1FW, A50-C-1G0, A50-C-1GE, A50-C-1GF, A50-C-1GG, A50-C-1H1, A50-C-1H2, A50-C-1H7, A50-C-1H9, A50-C-1HC, A50-C-1HD, A50-C-1K0, A50-C-1KC, A50-C-1MV, A50-C-1NH, A50-C-1QG, A50-C-1QK, A50-C-1RL, A50-C-1T7, A50-C-1U2, A50-C-1UG, A50-C-1V0, A50-C-1W2, A50-C-1ZQ, A50-C-1ZR, A50-C-1ZT, A50-C-1ZV, A50-C-1ZW, A50-C-1ZZ, A50-C-217, A50-C-219, A50-C-21C, A50-C-21E, A50-D-12R, Z40-A-03K, Z40-A-16D, Z40-A-17U, Z40-A-19C, Z40-A-1CH, Z40-A-1CL, Z40-B-10N, Z40-B-144, Z40-B-150, Z40-C-103, Z40-C-105, Z40-C-106, Z40-C-10R, Z40-C-11N, Z40-C-12X, Z40-C-12Z, Z40-C-131, Z40-C-13N, Z40-C-146, Z50-A-178, Z50-A-18P, Z50-A-19N, Z50-A-1D4, Z50-C-10M, Z50-C-10P, Z50-C-10Q, Z50-C-10R, Z50-C-113, Z50-C-114, Z50-C-115, Z50-C-11C, Z50-C-11E, Z50-C-11F, Z50-C-11J, Z50-C-11V, Z50-C-11W, Z50-C-138, Z50-C-13D, Z50-C-14N
Scroll to top
