BT.com
Wishlist
Toshiba H200 500GB 2.5" 5400rpm 64MB 8GB NAND Hybrid SSHD
Toshiba H200 500GB 2.5" 5400rpm...
£54.90
£54.90
Add to wishlist
Delivery
Standard 1-3 working days
Express Delivered tomorrow
Express Delivery
  • 00 h
  • 00 m
  • 00 s
Toshiba’s H200 2.5" internal solid state hybrid drive (SSHD) combines the storage capabilities of a hard drive with the performance and responsiveness of a solid state drive giving you large, high-performance storage that's ideal for gamers and everyday users. The H200’s fast read speeds are achieved through an optimized self-learning caching algorithm, providing quick access to your frequently-used applications, game saves, and data.
Toshiba H200 - hybrid hard drive - 500 GB - SATA 6Gb/s
Hybrid hard drive - internal
500 GB
Flash Memory Capacity
8 GB
NAND Flash Memory Type
Multi-level cell (MLC)
2.5"
SATA 6Gb/s
Buffer Size
64 MB
Spindle Speed
5400 rpm
RV Sensor, Native Command Queuing (NCQ), shock resistant, Halogen Free, Tunnel Magneto-resistive Recording (TMR) Head Technology, Ramp Load, Perpendicular Magnetic Recording (PMR), Advanced Format technology, Dual Stage Actuator (DSA), Data Protection Technology
69.85 mm x 100 mm x 7 mm
92 g
500 GB
8 GB
2.5"
SATA 6Gb/s
Buffer Size
64 MB
69.85 mm
100 mm
7 mm
92 g
Performance
Average Latency
5.56 ms
Spindle Speed
5400 rpm
Expansion & Connectivity
1 x SATA 6 Gb/s
Compatible Bay
2.5"
Power Consumption
3.3 Watt (read) , 3 Watt (write) , 0.75 Watt (low power idle)
RoHS, halogen-free
Package Type
Bulk
60 °C
Shock Tolerance (operating)
350 g @ 2 ms half-sine pulse
Shock Tolerance (non-operating)
900 g @ 1 ms half-sine pulse
Vibration Tolerance (operating)
1 g @ 5-500 Hz
Vibration Tolerance (non-operating)
5 g @ 15-500 Hz
Sound Emission
19 dB
Toshiba H200 500GB 2.5" 5400rpm 64MB 8GB NAND Hybrid...
£54.90
Save on this ideal PC Build kit!
Save £8.29
£74.07
Cables - Cables
£54.90
Save 50% On This 1m SATA Cable When Bought With This Item
Save £3.22
£58.12
Other bundles
£54.90
Save on Intel Optane 16GB with HDD
Save £5.00
£93.87
Scroll to top
