BT.com
Wishlist
Toshiba Global AC Adapter 45 Watt
Delivery
Standard 3-5 working days
This Toshiba Global AC Adapter is an external AC adapter designed to work with select Toshiba Satellite P100 notebook computers. Used as either a spare or replacement AC adapter, it has been tested and certified by Toshiba and meets or exceeds the specifications of the original AC adapter that came with your PC. This AC adapter powers your notebook computer via power outlet and lets you operate your computer as needed while recharging your notebook's battery. Stop weighing yourself down between office and home, get extra AC adapters to be kept at home, in the office or in your traveling bag.
Toshiba Global AC Adapter - power adapter - 45 Watt
Power adapter - external
170 g
United States
Input Voltage
AC 120/230 V
Output Voltage
19 V
Power Capacity
45 Watt
9.14 cm x 4.06 cm x 2.54 cm
1 year warranty
Chromebook CB30, CB35; Chromebook 2; Portégé Z10, Z10T, Z15t, Z20T; Satellite C55D, C70D, L30W, NB15t, P30W, U920T, U920T/00, U920T/023, U920t/Q001, U925T; Satellite Radius 12; Toshiba Satellite Click W35Dt; Toshiba WT310
United States
Input Voltage
AC 120/230 V
Frequency Required
50/60 Hz
Output Voltage
19 V
Max Electric Current
2.37 A
Power Capacity
45 Watt
Power cable 1.98 m
Touch fastener
RoHS
Limited warranty - 1 year
9.14 cm
4.06 cm
2.54 cm
170 g
Toshiba Chromebook CB30-A3120, CB35-A3120 , Toshiba Chromebook 2 CB30-B3121, CB30-B3122 , Toshiba Portégé Z10t-A, Z10t-A-001, Z10t-A-002-1, Z10t-A-003, Z10t-A-003-2, Z10t-A-005, Z10t-A-102, Z10t-A-103, Z10t-A-104, Z10t-A-106, Z10t-A-10H, Z10t-A-10M, Z10t-A-111, Z10t-A1110, Z10t-A1111, Z10T-A-112, Z10t-A-119, Z10t-A-11Q, Z10t-A-11Z, Z10t-A-121, Z10t-A-122, Z10t-A-12J, Z10t-A-12N, Z10t-A-12W, Z10t-A-12Z, Z10T-A-13R, Z10t-A-13T, Z10t-A-146, Z10t-A-14H, Z10t-A2111, Z15t-A1210, Z20t-B-10C, Z20t-B-10E, Z20t-B-10G, Z20t-B-10J, Z20t-B-10W, Z20t-B-10Z, Z20T-B-110, Z20t-B-111, Z20t-B-113, Z20t-B-115, Z20T-B-11E, Z20t-B-11P, Z20t-B-11Q , Toshiba Satellite C55D-A-12K, C70D-A-108, C70D-A-10C, C70D-A-111, C70D-A-114, L30W-B-00L, NB15t-A1302, NB15t-A1303, P30W-B-00W, U920T/00S, U920T/023, U920t/Q001, U920t-00E, U920T-00X, U920T-01G, U920t-028, U920t-100, U920t-101, U920t-102, U920T-104, U920t-107, U920t-108, U920t-109, U920t-10F, U920t-10G, U920t-10H, U920t-10J, U920t-10K, U920t-10L, U920t-10M, U920t-10N, U920t-10P, U920t-10Q, U920t-10T, U920t-10V, U920t-10W, U920t-10Z, U920t-116, U920t-117, U920t-118, U920t-119, U920t-11C, U920t-11D, U920t-11E, U920t-11F, U920t-11G, U920t-11H, U920t-11J, U920t-11N, U925t-S2100, U925T-S2120, U925t-S2300, U925t-S2301 , Toshiba Satellite Radius 12 P20W-C-103, P20W-C-104, P20W-C-10H, P20W-C-10K , Toshiba Satellite Click W35Dt-A3300, W35Dt-AST2N01 , Toshiba WT310
Scroll to top
