BT.com
Wishlist
Toshiba Canvio Slim 1TB USB 3.0 2.5" Hard Drive - Black
Toshiba Canvio Slim 1TB USB 3.0...
£64.70
Hurry, only 2 left in stock!
£64.70
Add to wishlist
Delivery
Standard 1-3 working days
Express Delivered tomorrow
Express Delivery
  • 00 h
  • 00 m
  • 00 s
SLIM STORAGE COMPANION
Store data securely on the new Canvio Slim external hard drives. Its elegant slim and lightweight design makes it a perfect travel companion. Transfer your files via SuperSpeed USB 3.0 and keep them safe using a password lock. The pre-loaded NTI® Backup Now EZ™ software allows easy automated backups. You can also use the Canvio Slim on PC and Mac thanks to Tuxera HTFS for Mac driver (included). And even access your data remotely and wirelessly from another PC, tablet or smartphone! Additionally you have 10GB free cloud storage.
PERFECT TRAVEL COMPANION
With a super slim design that looks good and is light enough to carry anywhere, you will want to store and share your data securely wherever you go.
AUTO-BACKUP SOFTWARE AND NFTS DRIVER FOR MAC INCLUDED
Pre-loaded NTI® Backup Now EZ™ software automates file, folder, and full system backup and recovery for complete peace of mind. And you can use the Canvio Slim on both Windows PC and Apple Macintosh platforms, thanks to the onboard Tuxera NTFS for Mac driver.
SUPERSPEED USB 3.0 FOR FASTER TRANSFERS
Powered by new USB 3.0 technology, the Canvio Slim is far faster than--but still compatible with--USB 2.0 technology. That's important for speedy transfer when organising your files.
SAFELY LOCKED AWAY
Lock your Canvio Slim with a password that's unique to you - and prevent unauthorised users from accessing important data stored on your hard drive.
WITH 10GB CLOUD STORAGE AND REMOTE ACCESS SOFTWARE
Store up to 10GB of data securely in the cloud and access it whenever you want, on your PC, smartphone or tablet. With remote access software for your mobile devices, the data on your Canvio Slim is always within easy reach too. Even when you're travelling
Toshiba StorE Slim - hard drive - 1 TB - USB 3.0
Hard drive - external (portable)
1 TB
2.5"
USB 3.0
Data Transfer Rate
5.0 Gbps (USB 3.0)
Password authentication
Power Source
USB bus
Enclosure Colour
Bundled with
10GB free Cloud Backup
1 TB
2.5"
USB 3.0
Bundled with
Performance
Interface Transfer Rate
5.0 Gbps (USB 3.0)
Expansion & Connectivity
1 x USB 3.0
Compatible Bay
2.5"
Power Source
USB bus
Software Included
NTI Backup NOW! EZ, Tuxera HTFS
Enclosure Colour
Other bundles
Toshiba Canvio Slim 1TB USB 3.0 2.5" Hard Drive -...
£64.70
Half Price Hard Drive Case with portable hard drives
Save £4.99
£69.69
Scroll to top
