BT.com
Wishlist
Toshiba AC Adaptor-19V DC,2.37A,45W 2-Pin
Toshiba AC Adaptor-19V DC,2.37A,45W...
£21.18
12 in stock
£21.18
Add to wishlist
Delivery
Standard 1-3 working days
Express Delivered on Wednesday
Express Delivery
  • 00 h
  • 00 m
  • 00 s
This Toshiba Global AC Adapter is an external AC adapter designed to work with select Toshiba Satellite P100 notebook computers. Used as either a spare or replacement AC adapter, it has been tested and certified by Toshiba and meets or exceeds the specifications of the original AC adapter that came with your PC. This AC adapter powers your notebook computer via power outlet and lets you operate your computer as needed while recharging your notebook's battery. Stop weighing yourself down between office and home, get extra AC adapters to be kept at home, in the office or in your traveling bag.
Toshiba Global AC Adapter - power adapter - 45 Watt
Power adapter - external
206 g
Input Voltage
AC 100-240 V
Output Voltage
19 V
Power Capacity
45 Watt
4.6 cm x 9.4 cm x 2.5 cm
1 year warranty
Portégé R30, Z30, Z930; Satellite C50, C55, C660/00, C660/01, C660/02, C70, C75, C850, C855, C870, C875, L50, L55, L70, L850, M50, NB10, P50, P845, S50, S70, T130, T130/01, T130/03, U50, U840, U845, U940, U940/K002, W30, Z30, Z930; Satellite Pro C50, C70, L70, L850, L850/R001, NB10, R50, T130/00
Input Voltage
AC 100-240 V
Frequency Required
50 - 60 Hz
Output Voltage
19 V
Max Electric Current
2.37 A
Power Capacity
45 Watt
No power cord is included
Cable management
RoHS
Limited warranty - 1 year
4.6 cm
9.4 cm
2.5 cm
206 g
Toshiba Portégé R30-A-10H, R30-A-10R, R30-A-138, Z30-A-108 (45 Watt), Z30-A-115, Z30-A-11G (45 Watt), Z30-A-12P (45 Watt), Z30-A-136 (45 Watt), Z30-A-138 (45 Watt), Z30-A-13E, Z30-A-13R, Z30-A-13U, Z30-A-13W (45 Watt), Z30-A-14K, Z30-A-159, Z30-A-1FL, Z930-08E (45 Watt) , Toshiba Satellite C50-A-108 (45 Watt), C50-A-10D (45 Watt), C50-A-12C (45 Watt), C50-A-14W (45 Watt), C50-A-1G4 (45 Watt), C50-A-1KQ, C50-B-10P, C50-B-12L, C50-B-12M, C50-B-13K, C50D-A-10Z, C50D-A-130 (45 Watt), C50D-A-147, C50D-B-10V, C50D-B-10X, C55-A-12W (45 Watt), C55-A-1F5 (45 Watt), C55-A-1GT (45 Watt), C55-A-1N2 (45 Watt), C55-A-1N4 (45 Watt), C55-A-1N5 (45 Watt), C55-A-1N8 (45 Watt), C55-A-1N9 (45 Watt), C55-A-1ND (45 Watt), C55-A-1NE (45 Watt), C55-A-1P2 (45 Watt), C55-A-1P7 (45 Watt), C55-A-1Q5 (45 Watt), C55-A-1QH (45 Watt), C55-A5388 (45 Watt), C55-A5390 (45 Watt), C70-A-14Z (45 Watt), C70-A-150 (45 Watt), C70-A-157 (45 Watt), C70-A-15D, C70-A-15G (45 Watt), C70-A-15U, C70-A-160 (45 Watt), C70-A-16N, C70D-A-10L, C70D-A-11C, C75-A-12D (45 Watt), C75-A-13M (45 Watt), C75-A-13T (45 Watt), C75-A-14C (45 Watt), C75-A-15E, C75-A7390 (45 Watt), C75D-A-10C, C850-1MJ (45 Watt), C855-244 (45 Watt), L50-A-1CW (45 Watt), L50-A-1EC, L50-A-1EH (45 Watt), L50-B-11Z, L50-B-120, L50-B-124, L50-B-13D, L50-B-13M, L50-B-159, L50-B-177, L50-B-17C, L50-B-181, L50-B-182, L50-B-18K, L50-B-196, L50-B-19M, L50-B-1C9, L50-B-1CC, L50-B-1D5, L50-B-1D6, L50-B-1DK, L50-B-1DP, L50-B-1DQ, L50-B-1DR, L50-B-1DW, L50-B-1DX, L50-B-1E2, L50-B-1E3, L50-B-1E4, L50-B-1GC, L50D-B-11Q, L50D-B-11V, L50D-B-11W, L50t-B-11R, L50t-B-11V, L70-A-10G (45 Watt), L70-A-13P (45 Watt), M50-A-108 (45 Watt), P50-A-113 (45 Watt), P50-A-137 (45 Watt), P50-A-13C (45 Watt), P50-A-13Q (45 Watt), P50-A-144, Z30-A-177, Z30t-A-10C , Toshiba Satellite Pro C50-A-1FM (45 Watt), C70-A-14X (45 Watt), NB10-A-105 (45 Watt), NB10-A-109 (45 Watt), R50-B-10H, R50-B-10K, R50-B-10L, R50-B-10R, R50-B-11C
Scroll to top
