BT.com
Wishlist
Toshiba AC Adapter 19v DC
Delivery
Standard 3-5 working days
Universal AC adapter is designed to power your notebook through your home or office electric socket. Toshiba's universal AC adapters can be used anywhere in the world with the appropriate AC plug adapter.
Toshiba - power adapter - 75 Watt
Power adapter - external
310 g
Input Voltage
AC 100-240 V
Output Voltage
19 V
Power Capacity
75 Watt
Output connectors
1 x power DC jack
12.7 cm x 3.1 cm x 5.1 cm
Portégé M800, R500, R500 3G-11, R500 3G-121; Satellite A500, A500/02, A660, A665, C650, C660, C670, C855, L550, L630, L650, L730, L735, L750, L755, L770, L775, P750, P770, T110, T130, U300, U400; Satellite Pro C660, L350, L450, L500, L550, L670, L770, T130, U300, U400; Tecra R840, R850
Input Voltage
AC 100-240 V
Frequency Required
50/60 Hz
1 x power DC jack
Output Voltage
19 V
Max Electric Current
3.95 A
Power Capacity
75 Watt
No power cord is included
TUV GS, PCT, CCC, cULus
12.7 cm
3.1 cm
5.1 cm
310 g
Toshiba Satellite A665-S5173, A665-SP6011M, C650-00P, C650D-005, C660-162, C660-19T, C660-1ME, C660-1MK, C660-1NF, C660-1PD, C660-1RK, C660-1T9, C660-1TM, C660-1U0, C660-1U6, C660-1WW, C660-1WZ, C660-1X0, C660-1X2, C660-1X4, C660-1X5, C660-1X6, C660-1X7, C660-1X9, C660-1XT, C660-1ZU, C660-21J, C660-21K, C660-21W, C660-21Z, C660-225, C660-22C, C660-22Q, C660-249, C660-24C, C660-258, C660-25U, C660-264, C660-26G, C660-26X, C660-28D, C660-28R, C660-28T, C660-28V, C660-2CR, C660-2D7, C660-2DL, C660-2DV, C660-2E1, C660-2E2, C660-2E3, C660-2EL, C660-2F2, C660-2FD, C660-2FE, C660-2G6, C660-2KW, C660-2L0, C660-2N3, C660-2Q7, C660-2QH, C660-2T6, C660-2T7, C660D-1EH, C670-104, C670-189, C670-19E, C670-1D5, C670-1DC, C855-15Q, C855-192, L650-10L, L730-10X, L735-142, L750-10N, L750-114, L750-12U, L750-12Z, L750-16J, L750-16L, L750-16V, L750-16W, L750-16X, L750-16Z, L750-170, L750-171, L750-176, L750-17D, L750-17N, L750-17P, L750-18R, L750-1DH, L750-1DJ, L750-1DK, L750-1DL, L750-1DM, L750-1DQ, L750-1DR, L750-1DU, L750-1DV, L750-1DW, L750-1DX, L750-1E5, L750-1E8, L750-1E9, L750-1EK, L750-1EZ, L750-1HR, L750-1KU, L750-1LC, L750-1RJ, L750-1RP, L750-1VV, L750-1VW, L755-1LQ, L770-119, L770-11U, L770D-10G, L770D-10H, L775-17H, P750-11H, P750-121, P750-133, P750-13F, P750-13G, P750-13L, P750-13M, P750-13N, P750-15G, P770, P770-115, P770-116, P770-117, P770-11G, P770-11M , Toshiba Satellite Pro C660-2DW, C660-2HE, C660-2JK, C660-2KL, C660-2N2, C660-2QC, C660-2QD, C660-2T9, L670-EZ1715D, L770-15T , Toshiba Tecra R840-002, R840-008, R840-009, R840-01J, R840-020, R840-021, R840-02X, R840-110, R840-12K, R840-13T, R840-146, R840-14T, R840-15J, R840-16W, R840-S8412, R840-S8422, R850-015, R850-017, R850-01D, R850-01F, R850-021, R850-02Y, R850-030, R850-034, R850-150, R850-151, R850-154, R850-17C, R850-17L, R850-182, R850-18E, R850-18H, R850-19J, R850-1C3, R850-1C7, R850-1D7, R850-1D8, R850-S8512, R850-S8522, R850-S8532, R850-S8552, R850-SP5171M
Scroll to top
