BT.com
Wishlist
Toshiba AC Adapter 19V 2.37A 45W includes power cable
Delivery
Standard Due date unavailable
Toshiba's Universal AC Adaptor can be used anywhere in the world with the appropriate AC plug adaptor. Same quality, reliability, and specification as the original Toshiba AC Adaptor included with your Notebook. So, why not buy an extra AC Adaptor to be kept at home, in the office, or when traveling.
Toshiba AC Adapter - power adapter - 45 Watt
Power adapter - external
Input Voltage
AC 100-240 V
Output Voltage
19 V
Power Capacity
45 Watt
9.4 cm x 2.7 cm x 4.3 cm
1 year warranty
Libretto W100; Portégé R930, Z30, Z30 4G/SSD-1EL, Z30T, Z830, Z930; Satellite C50Dt, C55D, C660, C670, C70D, C850, C850D, C855, C855D, C870, C870D, C875D, L50Dt, L830, L850, L850D, L870, L955, L955D, M50D, P50, P845t, T210, T230, U840, U840W, U940, Z830, Z930; Satellite Pro C660, C850, L850, NB10
Input Voltage
AC 100-240 V
Frequency Required
50 - 60 Hz
Output Voltage
19 V
Power Capacity
45 Watt
RoHS
Limited warranty - 1 year
9.4 cm
2.7 cm
4.3 cm
Toshiba Libretto W100, W100-106, W100-107, W100-10D, W100-10F , Toshiba Portégé R930-17N, R930-17Q, R930-17R, R930-17V, Z30 4G/SSD-1EL, Z30-A-11G, Z30-A-136, Z30-A-15M, Z30t-A-108, Z30T-B-10H, Z30T-B-10U, Z30t-C-119, Z830-11M, Z830-120, Z830-128, Z830-12C, Z930-10P, Z930-116, Z930-11C, Z930-131, Z930-13L, Z930-13M, Z930-13U, Z930-147, Z930-14K, Z930-14Q, Z930-15Z , Toshiba Satellite C50Dt-A-107, C55D-A-12K, C55D-A-13T, C660-1PD, C660-2N3, C660-2Q7, C660-2QH, C660-2T6, C660-2T7, C660D-1HK, C670-17Q, C70D-A-10H, C850-138, C850-141, C850-15L, C850-176, C850-17W, C850-18X, C850-190, C850-195, C850-197, C850-19P, C850-19Q, C850-1CH, C850-1CJ, C850-1GD, C850-1GQ, C850-1L9, C850-1MJ, C850D-105, C850D-119, C850D-11F, C850D-121, C855-283, C855D-12P, C855D-149, C855D-14C, C870-13N, C870-168, C870-177, C870-1DD, C870D-109, C870D-10M, C870D-10X, C875D-10E, L50Dt-A-109, L830-13J, L850-118, L850-16Z, L850-18T, L850-1EZ, L850-1HL, L850-1HM, L850-1HQ, L850-1HR, L850-1J4, L850-1MK, L850-1RX, L850-1RZ, L850D-114, L870-12L, L870-147, L870-160, L870-17C, L870-17D, L870-17E, L870-17G, L870-17H, L955-10D, L955D-105, L955D-107, L955D-10E, M50D-A-10R, P50-A-11G, P845t-104, T210-10X, T210-112, T230-01H, T230-01X, T230-01Y, T230-10J, T230-11P, T230-12E, T230-12F, T230-12G, T230-12H, T230-12Q, T230-131, T230-132, U840-10Q, U840-10T, U840W-108, U840W-10T, U940-101, U940-104, U940-10F, U940-11P, Z830-10M, Z830-11H, Z930-13C , Toshiba Satellite Pro C660D-1FM, C850-1J4, C850-1J5, L850-1C2, NB10-A-10L, NB10-A-111
Scroll to top
