BT.com
Wishlist
Toshiba 8GB TransMemory U202 USB 2.0 Drive - White
Delivery
Standard Due date unavailable
TransMemory™ U202
STORAGE MADE SIMPLE
The Toshiba TransMemory™ U202 USB flash drive makes it simple to store media – with a design that's small in size, but big on storage, with a choice of memory sizes. And with protection software, the TransMemory™ U202 also provides data security – enabling you to set a password for the entire device, or one specific block of data. Behind the practical and attractive design is a flash drive that you can take everywhere, for access to media anywhere.
PRACTICAL AND PORTABLE
With a small and lightweight design, the Toshiba TransMemory™ U202 is designed to go wherever you go. Simple and flexible storage is housed in a practical and attractive design, so documents, music, photos and more can go anywhere – effortlessly.
STORAGE MADE SAFER
Additional security software means that whatever you choose to store, it stays protected and private. With password support for the entire device, or specific blocks, your data is kept safe.
QUALITY YOU CAN TRUST
Toshiba is the inventor of flash memory, and has a well-earned worldwide reputation for producing high quality technology.
Toshiba TransMemory U202 - USB flash drive - 8 GB
USB flash drive
Interface Type
USB 2.0
Storage Capacity
8 GB
Enclosure Colour
White
Europe
Apple MacOS X 10.0.2 or later, Microsoft Windows 2000/XP/Vista/7/8
5 years warranty
USB flash drive
Storage Capacity
8 GB
Enclosure Colour
White
Compatibility
Non-specific
Europe
Read Rate
Up to 18 MB/s
Write Rate
Up to 5 MB/s
Interface Type
USB 2.0
Limited warranty - 5 years
21.4 mm
51.4 mm
8.4 mm
8 g
50 °C
20 - 95% (non-condensing)
Scroll to top
