Click to visit BT.com
BT.com
Wishlist
Toshiba 750GB StorE Alu2 USB 2.0 2.5" Portable Hard Drive
Quicklinx: 77YGWS00
Mfr#: PX1709E-1HG5
In a stylish design, Toshiba USB 2.0 external hard drives are the perfect storage solution for your digital videos, photos and music files. These high speed hard drives, provide excellent performance, and with their fanless design, are near-silent in operation.
  • Solid aluminum casing
  • Low power consumption
  • Hi-Speed USB 2.0
  • Interface Transfer rate: Up to 480 Mbps
  • Dimensions (mm): 120 (H) x 11.7 (W) x 77 (L) mm (750 GB)
  • Weight (g): 175 / 197g
  • Certification: CE, NCRS, SASO, RoHS
  • 2 year warranty
System requirements
  • Microsoft® Windows®, XP/Vista/Windows 7
  • 1 x USB port
Box content
  • STOR.E ALU 2 2.5" (6,4cm) - HDD Drive
  • USB cable
  • Quick start guide
  • User's manual (pre-installed on the hard drive)
  • Warranty leaflet
Toshiba StorE Alu2 - hard drive - 750 GB - USB 2.0
Hard drive - external ( portable )
750 GB
2.5"
USB 2.0
Data Transfer Rate
480 Mbps
Buffer Size
8 MB
Bus Powered by USB
Enclosure Colour
1.5 cm x 7.7 cm x 12 cm
175 g
Microsoft Certification
Compatible with Windows 7
Portégé R830-10Q, R830-138, R830-139, R830-13C
750 GB
2.5"
USB 2.0
Buffer Size
8 MB
Bus Powered by USB
1.5 cm
7.7 cm
12 cm
175 g
Performance
Interface Transfer Rate
480 Mbps
Expansion & Connectivity
1 x USB 2.0
Microsoft Windows Vista / XP / 7
1 x USB cable - external
GOST, SASO, RoHS
Enclosure Colour
Toshiba Portégé R830-10Q, R830-138, R830-139, R830-13C
Resources
The following resources are available for the Toshiba 750GB StorE Alu2 USB 2.0 2.5" Portable Hard Drive
