BT.com
Wishlist
Toshiba 640GB 2.5" 5400 8MB SATA300
Delivery
Standard Due date unavailable
Toshiba storage device division's MK6465GSX 2.5-inch hard disk drive provides optimum mobility, unparalleled performance and increased storage space for the digital user constantly on the go. The 640GB drive is the world's highest capacity 2.5-inch dual platter HDD to date.
With a rotational speed of 5400RPM, the series is ideal for applications with limited architectural space such as laptops and mini notebooks but demand top performance. In addition, compared to similar 3.5-inch drives, the power consumption and heat dissipation are reduced by over 80%. This drive incorporates the Serial ATA technology and support a 3.0 Gbps interface data transfer rate.
Toshiba MK6465GSX - hard drive - 640 GB - SATA 3Gb/s
Hard drive - internal
640 GB
2.5" x 1/8H
SATA 3Gb/s
Data Transfer Rate
144 MBps
Buffer Size
8 MB
Spindle Speed
5400 rpm
70 mm x 100 mm x 9.5 mm
101 g
Microsoft Certification
Compatible with Windows 7
1 year warranty
640 GB
2.5" x 1/8H
SATA 3Gb/s
Buffer Size
8 MB
70 mm
100 mm
9.5 mm
101 g
Performance
Drive Transfer Rate
144 MBps (external)
Seek Time
12 ms (average) / 22 ms (max)
Track-to-Track Seek Time
2 ms
Average Latency
5.55 ms
Spindle Speed
5400 rpm
Reliability
Non-Recoverable Errors
1 per 10^14
Expansion & Connectivity
1 x SATA 3 Gb/s
Compatible Bay
2.5" x 1/8H
1 year warranty
Limited warranty - 1 year
5 °C
55 °C
Scroll to top
