BT.com
Wishlist
Toshiba 6 Cell 4400mAH Li-Ion Battery
Delivery
Standard Due date unavailable
Toshiba batteries are of the same quality, reliability, and specification as the original primary pack included with your Notebook. Whether replacing an old battery, or simply wishing to carry a spare, the Toshiba range will enable you to be more productive and provide you with the power you need, when you need it.
Toshiba Battery Pack - laptop battery - Li-Ion - 4400 mAh
Laptop battery
320.7 g
Lithium Ion 6-cell - 4400 mAh
Batteries Qty
1
20.45 cm x 5.18 cm x 2.02 cm
1 year warranty
Qosmio X870, X870/00, X870/016; Satellite C50, C850, C850/04, C850/05, C855, C870, C875, L830, L830/022, L840, L850, L850/00, L850/05, L850D/001, L850D/002, L855, L870, L875, P845, P850, P855, P870, P870/017, P870/019, P875; Satellite Pro C840, C850, C850/3005, C870, L830, L850, L850/R001, L870
Laptop battery
Quantity
1
6-cell Lithium Ion
Voltage Provided
10.8 V
4400 mAh
Limited warranty - 1 year
20.45 cm
5.18 cm
2.02 cm
320.7 g
Toshiba Qosmio X870-16E , Toshiba Satellite C50-A-15L, C850-1DZ, C850-1G6, C850-1GP, C850-1GQ, C850-1K7, C850-1K9, C850-1KG, C850-1KW, C850-1M9, C850-1MH, C850-1MJ, C850-1MN, C850-1MZ, C850-1NM, C850-1NN, C850-1P6, C850-1PM, C850D-10J, C850D-12Q, C850D-137, C850D-13G, C855-1LP, C855-1QK, C855-1T4, C855-1UD, C855-1Z6, C855-21U, C855-22N, C855-23Z, C855-244, C855-245, C855-24C, C855-25T, C855-285, C855-28J, C855-2FG, C855-2G2, C855-2GQ, C855-2HC, C855-2HT, C855-2HU, C855-2HV, C855-2HW, C855-2J2, C855-2J3, C855-2J4, C855-2J7, C855-2JK, C855-2KR, C855-2L9, C855-2LC, C855-2LJ, C855-2M1, C855-2M3, C855D-10W, C855D-13T, C855D-14X, C855D-15V, C855D-162, C855D-16J, C855D-170, C855D-S5203, C855D-S5238, C855D-SP5162KM, C855-S5107, C855-S5132NR, C855-S5236, C855-S5355, C855-S5630, C855-SP5266KM, C870-17Q, C870-17W, C870-1DJ, C870-1E8, C870-1FD, C870-1FF, C870-1H1, C870-1HR, C870-1J1, C870-1J4, C870-1JE, C870-1JL, C870-1JR, C870-1K1, C870D-122, C870D-12F, C870D-12M, C875-13H, C875-14Z, C875-S7132NR, L830-14J, L830-14M, L830-16E, L830-16G, L830-16M, L830-16W, L850-1F0, L850-1MK, L850-1NP, L850-1T0, L850-1T5, L850-1T7, L850-1UT, L850-1UW, L850-1V2, L850-1V6, L850-1VF, L850-1VV, L850-1W5, L850-1WU, L850-1WZ, L850-1XE, L850-1XK, L850-1XW, L850-1Z2, L850D-13F, L855-14J, L855-15J, L855-162, L855-166, L855-16H, L855-171, L855-175, L855-176, L855-17Z, L855-180, L855D-10L, L855D-S5139NR, L855D-SP5169KM, L855D-SP5266KM, L855-S5121, L855-S5138NR, L855-S5157, L855-S5162, L855-S5163, L855-S5187, L855-S5372, L855-S5375, L870-17K, L870-192, L870-193, L870-196, L870-198, L870-19M, L870-19N, L875-13C, L875-13D, L875D-10R, L875D-S7131NR, P845-S4200, P845t-110, P845t-112, P850-335, P850-337, P855-33Q, P855-34L, P855-SP5302SL, P870-31K, P870-32P, P870-332, P870-333, P870-334, P870-335, P870-338, P875-32K, P875-32L, P875-32Q, P875-32R , Toshiba Satellite Pro C850/3005, C850-1H3, C850-1HK, C850-1MW, L830-15M, L830-17T, L850/R001, L850-1Z8
Scroll to top
