BT.com
Wishlist
Toshiba 500GB StorE Alu2 2.5" Silver Portable Hard Drive
Delivery
Standard Due date unavailable
In a stylish design, Toshiba USB 2.0 external hard drives are the perfect storage solution for your digital videos, photos and music files. These high speed hard drives, provide excellent performance, and with their fanless design, are near-silent in operation.
Key Features
  • High speed USB 2.0
  • Low power consumption
  • Solid aluminium casing
  • Fanless design
Specification
  • Rotational speed 5400 rpm
  • Data Buffer 2 MB (@ < 250 GB), 8 MB (@ > 250 GB)
  • On-bus power Up to 5 W
  • Formatted capacity 320 GB, 500 GB, 640 GB
  • Form factor 2.5''
  • Power Supply USB power/data connection
  • System Requirements Microsoft® Windows®, XP/Vista/Windows 7, 1 x USB port
  • Box content: USB cable, Quick start guide, User's manual (pre-installed on the hard drive), Warranty leaflet
  • Certifications CE, NCRS, SASO, GOST (3.5"), RoHS
  • USB Interface High Speed USB 2.0
  • Dimensions (mm) 129 (H) x 14 (W) x 74 (L)
  • Interface Transfer rate Up to 480 Mbps
  • Weight (g) 175g
Toshiba StorE Alu2 - hard drive - 500 GB - USB 2.0
Hard drive - external ( portable )
500 GB
2.5"
USB 2.0
Data Transfer Rate
480 Mbps
Buffer Size
8 MB
Power Source
USB bus
Enclosure Colour
Silver
7.4 cm x 12.9 cm x 1.4 cm
175 g
Microsoft Certification
Compatible with Windows 7
Toshiba LX830; NB510; NB520; Portégé R830, R930, Z830, Z930; Qosmio F750, X770, X870; Satellite C660, C670, C850, C850D, C855, C855D, C870, C870D, C875, L730, L735, L750, L750D, L755, L755D, L775, L775D, L830, L850, L850D, L855, L855D, L870, L875, L875D, L955D, P750, P770, P845T, P850, P855, P875, R830, R930, U840, U840W, U920t, U940, Z830, Z930; Satellite Pro C660, C850, L770, L830, L850, L870; Tecra A11, R840, R940, R950
500 GB
2.5"
USB 2.0
Buffer Size
8 MB
7.4 cm
12.9 cm
1.4 cm
175 g
Performance
Interface Transfer Rate
480 Mbps
Expansion & Connectivity
Compatible Bay
2.5"
Power Source
USB bus
1 x USB cable - external
GOST, SASO, RoHS
Enclosure Colour
Silver
Toshiba LX830-11G , Toshiba Portégé R930-14T, R930-14X, R930-14Z, R930-151, R930-152, R930-153, R930-18L, R930-1CW, R930-1CX, R930-1CZ, R930-1D0, R930-1D7, Z930-12G, Z930-12H, Z930-137, Z930-138, Z930-146 , Toshiba Qosmio X870-143, X870-144 , Toshiba Satellite C850-19D, C850-19Z, C850-1C0, C850-1C1, C850-1C2, C850-1C4, C850-1C9, C850-1D2, C850-1DV, C850-1DW, C850-1LH, C850-1LW, C850D-11F, C850D-11Q, C850D-121, C850D-12L, C855-1RK, C855-1RL, C855-1RM, C855-1RN, C855-1RP, C855-1RT, C855-1RU, C855-1RV, C855-1RX, C855-1TC, C855-1TD, C855-1TE, C855-1TF, C855-1TJ, C855-1TV, C855-1VN, C855-1VT, C855-1VU, C855-1W3, C855-1W4, C855-1W7, C855-1W9, C855-1WC, C855-1WM, C855-1WP, C855-1WQ, C855-1WR, C855-1WT, C855-1WU, C855-253, C855-28U, C855-2EE, C855-2ET, C855-2EU, C855-2EZ, C855-2F0, C855-2F1, C855-2F8, C855D-137, C855D-15Z, C870-17D, C870-17F, C870-18V, C870-198, C870-1F3, C870-1GF, C870-1H2, C870D-11K, C870D-11X, C875-130, L830-138, L830-139, L830-144, L830-145, L850-1LK, L850-1V0, L850D-12P, L850D-12Q, L855-148, L855-149, L855-14C, L855-14Q, L855-14R, L855-14U, L855-15L, L870-169, L870-18Q, L875-12P, L955D-104, P845t-101, P845t-102, P845T-108, P845t-10G, P850-31L, P850-320, P850-321, P850-32D, P855-32G, P855-32J, P855-335, P855-34P, P875-31E, P875-31P, R930-16W, U840W-10J, U920t-108, U920t-109, U920t-10F, U940-10M, U940-10N, U940-10P, U940-117, Z930-132, Z930-13N , Toshiba Satellite Pro C850-19G, C850-1C3, C850-1CV, C850-1CW, C850-1D4, C850-1DC, C850-1DE, C850-1EQ, C850-1ER, C850-1FJ, C850-1FN, C850-1FR, C850-1GR, C850-1H8, C850-1HD, C850-1HE, C850-1K3, C850-1K4, C850-1LV, C850-1M7, L830-13E, L830-13R, L830-14F, L830-15W, L850-1KM, L850-1L4, L850-1MH, L850-1MJ, L850-1P7, L850-1P8, L850-1UJ, L850-1UK, L870-171, L870-172, L870-17X, L870-18R , Toshiba Tecra R940-1FD, R940-1FE, R940-1FF, R940-1FH, R940-1FT, R940-1GQ, R940-1GT, R940-1JF, R940-1JG, R940-1JH, R950-153, R950-155, R950-176, R950-18K, R950-1EJ, R950-1EK, R950-1EL
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
5* toshiba 500GB store alu2 2.5
Reviewed by Anonymous on 06/03/2012
i think this is the product of the next generation
5* great value for money
Reviewed by Dave Colton on 16/10/2012
just had to reformat for the Macbook Pro and away it went - quiet and fast for a USB 2 device
5* Ms
Reviewed by Susan Cross on 02/01/2012
it is a very good product
Scroll to top
