BT.com
Wishlist
Toshiba 500GB Canvio Connect II USB 3.0 2.5" Portable HD Blue
Toshiba 500GB Canvio Connect II USB...
£45.93
£45.93
Add to wishlist
Delivery
Standard Due date unavailable
Canvio Connect II - Capacity to connect
Access your fi les anywhere and from any device. The new Canvio Connect II is a smart storage solution that will soon become your favourite data companion. Not only do you get up to 2 TB of portable storage, the Canvio Connect II can also turn your PC into your own personal cloud server. Pre-loaded remote access software gives you instant access to your fi les from all your devices, wherever you are.
Backing up your files is a breeze, thanks to the pre-installed NTI Backup Now EZ software. A NTFS driver for Mac is also included. And all this is packed into a solid, stylish enclosure that fit in the palm of your hand.
Remote access software
Remote access software turns your PC into a personal cloud storage server.
10 GB cloud storage
Enjoy the additional 10 GB free space in the cloud for your important backups.
Auto backup software
The pre-loaded NTI Backup Now EZ software provides reliable backup and recovery.
Top features:
- SuperSpeed USB 3.0
- 10 GB cloud storage
- Remote access software for PC, tablet and smartphone
- Auto-backup software onboard
- NTFS driver for Mac included
Box Content
- Canvio Connect II
- NTI Backup Now EZ software (pre-loaded)
- Tuxera NTFS for Mac driver software (pre-loaded)
- Pogoplug PC for Toshiba (pre-loaded)
- USB 3.0 micro-B cable
- Quick Start Guide
- User Manual (pre-installed on the hard drive)
- Warranty Leaflflet
Toshiba Canvio Connect II - hard drive - 500 GB - USB 3.0
Hard drive - external (portable)
500 GB
2.5"
USB 3.0
Data Transfer Rate
5.0 Gbps (USB 3.0)
Bus Powered by USB, NTFS formatted
Power Source
USB bus
Enclosure Colour
Blue
7.8 cm x 10.9 cm x 1.4 cm
165 g
Bundled with
10GB free Cloud Backup
500 GB
2.5"
USB 3.0
7.8 cm
10.9 cm
1.4 cm
165 g
Bundled with
Performance
Interface Transfer Rate
5.0 Gbps (USB 3.0)
Expansion & Connectivity
1 x USB 3.0 - 10 pin Micro-USB Type B
Compatible Bay
2.5"
Power Source
USB bus
Software Included
NTI Backup NOW! EZ, Pogoplug PC, Tuxera NTFS Driver for Mac
Apple MacOS X 10.6.6 or later, Microsoft Windows 7 / 8 / 8.1
System Requirements Details
750 MHz - RAM 256 MB
1 x USB 3.0 cable - USB Type A to micro-B - external
Enclosure Colour
Blue
Scroll to top
