Click to visit BT.com
BT.com
Wishlist
Toshiba 3TB Canvio USB 3.0 3.5" Desktop Hard Drive (Black)
4.0*
Quicklinx: 8L58WS00
Mfr#: HDWC130EK3J1
Form Factor: 3.5"
Capacity: 3TB
Interface: SuperSpeed USB
Express delivery Delivered on Wednesday
Hurry, only 2 left in stock!
£89.98
Store data securely on the new STOR.E CANVIO external hard drives. It's quick and easy to transfer your files via SuperSpeed USB 3.0, and you can also organise data and backup files with pre-loaded NTI® Backup Now EZ™ software. Backward compatible with USB 2.0, the STOR.E CANVIO features versatile mounting options and is available in two colour variations.
Smart. Safe. Speedy
The STOR.E CANVIO Desktop is the smart, speedy way to preserve your favourite files and memories. USB 3.0 makes it super-fast, and it`s backwards compatible so connecting to USB 2.0 devices is no problem. The pre-loaded NTI® Backup Now EZ™ software is a complete back-up solution to keep your files safe. And password encryption goes the extra mile to guard against intruders.
  • Super Speed Storage USB 3.0
  • Backup Software onboard
  • Password encryption
  • Warranty - 2 year(s)
Toshiba StorE Canvio - hard drive - 3 TB - USB 3.0
Hard drive - external ( desktop )
3 TB
3.5"
USB 3.0
Data Transfer Rate
5.0 Gbps (USB 3.0)
Password authentication, NTFS formatted
Power Source
Included AC adapter
Enclosure Colour
4.2 cm x 12.9 cm x 16.7 cm
United Kingdom
Microsoft Certification
Compatible with Windows 7
2 years warranty
3 TB
3.5"
USB 3.0
4.2 cm
12.9 cm
16.7 cm
Performance
Interface Transfer Rate
5.0 Gbps (USB 3.0)
Expansion & Connectivity
1 x USB 3.0 - 10 pin Micro-USB Type B
Power Source
Included AC adapter
Power adapter
AC 120/230 V
Software Included
NTI Backup NOW! EZ
Microsoft Windows Vista / XP / 7
System Requirements Details
Windows XP/Vista/7 - 750 MHz - RAM 256 MB ( USB 2.0 )
1 x USB 3.0 cable - USB Type A to micro-B - external
Enclosure Colour
United Kingdom
Toshiba 3TB Canvio USB 3.0 3.5 Bundle deal on Toshiba 3TB Canvio USB 3.0 3.5" Desktop Hard Drive (Black)
Including:
Intenso 32GB Rainbow Transparent USB Flash Drive Intenso 32GB Rainbow Transparent USB Flash Drive worth £5.48 | in stock
£94.07
saving £1.39
Customer reviews
Write a review for the Toshiba 3TB Canvio USB 3.0 3.5" Desktop Hard Drive (Black) here!
Just the Job
Reviewed by Don Grunbaum. Review Posted 15/05/2013
Installed easily on both Windows XP and 7 with no problems. Very quiet so what more could you ask for?
  • Overall 5*
  • Ease of use 5*
  • Value for money 5*
5 Star Product
Reviewed by Anonymous Review Posted 02/03/2015
I got this for my Xbox One and is perfect, just plug usb and mains in and your done Xbox does the rest for you. I have found it quick and very quite and goes into power save if Xbox is turned off. Also it has the matching matt and gloss finish as Xbox One, bonus.
  • Overall 5*
  • Ease of use 5*
worst hard disk ever
Reviewed by Luca. Review Posted 30/08/2014
failed to turn on after a few months, impossible to open up.
  • Overall 2*
  • Ease of use 1*
  • Value for money 2*
toshiba canvio 3tb hard drive
Reviewed by kevin blake. Review Posted 07/08/2014
Utter garbage in my opinion. I bought 2 drives. One has been perfect other died with all my files after 6 months. I sent it off to germany and got the black version back as a replacement, my original was two tone black and white. This replacement drive was much slower to access my files and when the drive went to sleep, too an age to wake up again. Over the last few months its took longer and longer to wake and now it looks like its decided to give up altogether. Its looking like ive lost 2tb of data. Stay well away of toshiba drives, Ive got some seagate goflex drives, I wish i'd stuck with buying those.
  • Overall 1*
  • Ease of use 3*
  • Value for money 1*
The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
Form Factor: 3.5"
Capacity: 3TB
Brand: Toshiba
Price Range Inc VAT: 50 - 100
