BT.com
Wishlist
Toshiba 3TB Canvio Connect II USB 3.0 2.5" Portable Hard Drive Gold
Toshiba 3TB Canvio Connect II USB...
£113.44
£113.44
Add to wishlist
Delivery
Standard 1-3 working days
Access your files anywhere and from any device. The Canvio Connect II is a smart storage solution that fits in the palm of your hand.
Toshiba Canvio Connect II - hard drive - 3 TB - USB 3.0
Hard drive - external (portable)
3 TB
2.5"
USB 3.0
Data Transfer Rate
5.0 Gbps (USB 3.0)
Bus Powered by USB, NTFS formatted
Power Source
USB bus
Enclosure Colour
Satin gold
7.8 cm x 10.9 cm x 1.95 cm
230 g
Bundled with
10GB free Cloud Backup
3 TB
2.5"
USB 3.0
7.8 cm
10.9 cm
1.95 cm
230 g
Bundled with
Performance
Interface Transfer Rate
5.0 Gbps (USB 3.0)
Expansion & Connectivity
1 x USB 3.0 - 10 pin Micro-USB Type B
Compatible Bay
2.5"
Power Source
USB bus
Software Included
NTI Backup NOW! EZ, Pogoplug PC, Tuxera NTFS Driver for Mac
Apple MacOS X 10.6.6 or later, Microsoft Windows 7 / 8 / 8.1
System Requirements Details
750 MHz - RAM 256 MB
1 x USB 3.0 cable - USB Type A to micro-B - external
Enclosure Colour
Satin gold
Other bundles
Toshiba 3TB Canvio Connect II USB 3.0 2.5" Portable...
£113.44
Half Price Hard Drive Case with portable hard drives
Save £4.99
£118.43
Scroll to top
