BT.com
Wishlist
Toshiba 320GB Slim 7mm SATA 6GB/s 2.5" 5400RPM Hard Drive
Delivery
Standard Due date unavailable
The MQ01ABF series has been engineered to deliver high performance, combined with low energy consumption efficiency in Ultrabooks and high-end multimedia devices with data intensive applications.
Forming part of a series of advanced format technology HDDs, the MQ01ABF032 is developed to deliver a higher internal transfer rate with industry-leading recording density, making it ideally suited to media intensive applications. It is free from halogen, antimony trioxide and red phosphorus.
Toshiba MQ01ABF032 - hard drive - 320 GB - SATA 6Gb/s
Hard drive - internal
320 GB
2.5"
SATA 6Gb/s
Buffer Size
8 MB
Spindle Speed
5400 rpm
69.85 mm x 100 mm x 7 mm
92 g
Microsoft Certification
Compatible with Windows 7
320 GB
2.5"
SATA 6Gb/s
Buffer Size
8 MB
Bytes per Sector
4096
69.85 mm
100 mm
7 mm
92 g
Performance
Seek Time
22 ms (max)
Track-to-Track Seek Time
2 ms
Spindle Speed
5400 rpm
Reliability
Non-Recoverable Errors
1 per 10^14
Expansion & Connectivity
1 x SATA 6 Gb/s - 7 pin Serial ATA
Compatible Bay
2.5"
Power Consumption
1.5 Watt (active) , 0.55 Watt (idle)
RoHS
5 °C
55 °C
Shock Tolerance
400 g @ 2ms half-sine pulse (operating) / 900 g @ 1ms half-sine pulse (non-operating)
Vibration Tolerance
1 g @ 5-500 Hz (operating)
Sound Emission
21 dB
Scroll to top
