Click to visit BT.com
BT.com
Wishlist
Toshiba 32" High Definition LED TV
Quicklinx: 81WKWS00
Mfr#: 32BL502B
Essential accessories
With striking style and quality, the 32BL502 delivers high definition image quality and all the benefits of LED technology; amazing color, brightness and image clarity all in a thin, space-saving, elegant design. With the reassurance of Toshiba quality, the BL502 series also includes built-in Freeview digital TV access, so you can enjoy subscription-free access to 50 digital TV channels and 24 radio stations without the need for an additional set top box.
An electronic program guide lets you plan your week's viewing, plus enjoy video, photo and audio playback via USB, and the convenience of multiple HDMI inputs and PC input that make it easy to connect to other digital entertainment devices in your home.
Toshiba 32BL502B REGZA BL Series - 32" LED TV
LED-backlit LCD TV
Energy Class
Class A
135 Watt
Power Consumption (On mode)
37 W
Energy Consumption per Year
54 kWh
Diagonal Class
32"
Commercial Use
Hotel / hospitality
77 cm x 20.5 cm x 52.7 cm - with stand
10.65 kg
Resolution
1366 x 768
Display Format
720p
Video Interface
Component, composite, HDMI, SCART
HDMI Ports Qty
2 ports
PC Interface
VGA (HD-15)
HDCP Compatible
LCD Backlight Technology
LED backlight
Image Aspect Ratio
16:9
TV Tuner
1x analogue, 1x digital
Digital TV Tuner
DVB-T
Analogue TV Tuner
PAL, SECAM
Commercial Features
Hotel mode
Settings Cloning Capability
Audio Description (AD), Automatic Format Detection (AFD), game mode, 3D Color Management, Digital Noise Reduction (DNR), MPEG Noise Reduction, Automatic Channel Install (ACI), NTSC playback on PAL TV
Sound Output Mode
Stereo
Speaker System
2 speakers
Stereo Reception System
NICAM
USB Port
Yes , 1 ports
LED-backlit LCD TV
Energy Class
Class A
135 Watt
37 W
54 kWh
Diagonal Class
32"
Commercial Use
Hotel / hospitality
Series
REGZA BL Series
TV Tuner
Video Interface
HDMI Ports Qty
2 ports
PC Interface
VGA (HD-15)
HDCP Compatible
Dimensions
With stand
77 cm
20.5 cm
52.7 cm
10.65 kg
Enclosure Colour
Display
Resolution
1366 x 768
Display Format
720p
Image Aspect Ratio
16:9
LED backlight
Dynamic Contrast Ratio
3000000:1
Brightness
380 cd/m²
Widescreen Modes
Conventional 4:3
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Response Time
9 ms
Max V-Sync Rate
50 Hz
Comb Filter
3D digital
Colour Temperature Control
Commercial Features
Hotel mode
Stands & Mounts
Stand
Included
Stand Design
Tabletop
Flat Panel Mount Interface
200 x 100 mm
TV Tuner
Analogue TV Tuner
PAL, SECAM
NICAM
Digital TV Tuner
Digital TV Tuner
DVB-T
Digital TV Service
FREEVIEW
Digital Channel Qty
800 channels
Video Features
Analogue Video Input Signals
NTSC, PAL, SECAM
Teletext
Teletext Memory
1000 pages
Electronic Programme Guide
Now & Next
Media Player
USB Port
Yes , 1 ports
Radio
Preset Station Qty
24 channels
Audio System
Sound Output Mode
Stereo
Speaker System
2 speakers
Output Power / Total
12 Watt
Speakers
2 x main channel speaker - built-in - 6 Watt
Connector Type
2 x HDMI ( 19 pin HDMI Type A ) , 1 x headphones ( mini-phone stereo 3.5 mm ) , 1 x composite video input , 1 x SCART ( 21 PIN SCART ) , 1 x VGA / component video input ( 15 PIN HD D-Sub (HD-15) ) , 1 x USB ( 4 PIN USB Type A )
Power supply
Power Consumption Stand by / Sleep
0.5 Watt
