Click to visit BT.com
BT.com
Wishlist
Toshiba 32" High Definition LCD TV with built-in DVD player
Quicklinx: 81XDWS00
Mfr#: 32DV504B
Essential accessories
The ideal choice for when space is limited, the 32DV504 is an LCD TV with a built-in DVD player offering the reassurance of Toshiba quality and all-in-one convenience. It features stunning high definition image quality and built-in Freeview digital TV, for access to up to 50 digital TV channels and 24 radio stations without subscription.
Multiple HDMI inputs let you connect all your digital devices to this TV, with USB connectivity enabling you to enjoy videos, photos and music from USB drive directly via the TV.
Toshiba 32DV504B REGZA DV Series - 32" LCD TV
Diagonal Class
32"
Commercial Use
Hotel / hospitality
78.8 cm x 20.5 cm x 55.7 cm - with stand
11.5 kg
Resolution
1366 x 768
Display Format
720p
Video Interface
Component, composite, HDMI, SCART
HDMI Ports Qty
2 ports
PC Interface
VGA (HD-15)
HDCP Compatible
Image Aspect Ratio
16:9
TV Tuner
1x analogue, 1x digital
Analogue TV Tuner
PAL, SECAM
Commercial Features
Hotel mode
Settings Cloning Capability
Audio Description (AD), Automatic Format Detection (AFD), game mode, 3D Color Management, Digital Noise Reduction (DNR), MPEG Noise Reduction, Automatic Channel Install (ACI), NTSC playback on PAL TV
Sound Output Mode
Stereo
Speaker System
2 speakers
Stereo Reception System
NICAM
DVD
DVD player - built-in
USB Port
Yes , 1 ports
LCD TV
Diagonal Class
32"
Commercial Use
Hotel / hospitality
Combined with
Built-in DVD player
Series
REGZA DV Series
TV Tuner
Video Interface
HDMI Ports Qty
2 ports
PC Interface
VGA (HD-15)
HDCP Compatible
Dimensions
With stand
78.8 cm
20.5 cm
55.7 cm
11.5 kg
Display
Resolution
1366 x 768
Display Format
720p
Image Aspect Ratio
16:9
Dynamic Contrast Ratio
100000:1
Brightness
450 cd/m2
Widescreen Modes
Conventional 4:3
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Response Time
8 ms
Max V-Sync Rate
50 Hz
Comb Filter
3D digital
Colour Temperature Control
Commercial Features
Hotel mode
Stands & Mounts
Stand
Included
Stand Design
Tabletop
DVD
Media Type
DVD-R, DVD-RW, DVD, CD
JPEG photo playback, MP3 playback
TV Tuner
Analogue TV Tuner
PAL, SECAM
NICAM
Digital TV Tuner
Digital TV Service
FREEVIEW
Digital Channel Qty
800 channels
Video Features
Analogue Video Input Signals
NTSC, PAL, SECAM
Teletext
Teletext Memory
1000 pages
Electronic Programme Guide
Digital EPG
Media Player
USB Port
Yes , 1 ports
Radio
Preset Station Qty
24 channels
Audio System
Sound Output Mode
Stereo
Speaker System
2 speakers
Output Power / Total
12 Watt
Speakers
2 x main channel speaker - built-in - 6 Watt
Connector Type
2 x HDMI ( 19 pin HDMI Type A ) , 1 x VGA / component video input ( 15 PIN HD D-Sub (HD-15) ) , 1 x composite video input , 1 x SCART ( 21 PIN SCART ) , 1 x USB ( 4 PIN USB Type A ) , 1 x SPDIF output ( RCA phono ) , 1 x headphones ( mini-phone stereo 3.5 mm )
