Click to visit BT.com
BT.com
Wishlist
Toshiba 32" Full HD LCD TV
Quicklinx: 81X5WS00
Mfr#: 32BV702B
Essential accessories
Letting you enjoy the best possible viewing, the 32BV702 delivers Toshiba quality at highly affordable prices, featuring stunning full high definition images in an elegant design. Freeview digital TV access is built in, so you can enjoy subscription-free access to 50 digital TV channels and 24 radio stations without the need for an additional set top box.
Multiple HDMI inputs let you easily connect all your digital devices to this TV, with USB connectivity enabling you to enjoy videos, photos and music from USB drive on the big screen.
Toshiba 32BV702B REGZA BV Series - 32" LCD TV
LCD TV
Diagonal Class
32"
Commercial Use
Hotel / hospitality
78.8 cm x 20.5 cm x 55.7 cm - with stand
11.05 kg
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Video Interface
Component, composite, HDMI, SCART
HDMI Ports Qty
2 ports
PC Interface
VGA (HD-15)
HDCP Compatible
Image Aspect Ratio
16:9
TV Tuner
1x analogue, 1x digital
Analogue TV Tuner
PAL, SECAM
Commercial Features
Hotel mode
Settings Cloning Capability
Audio Description (AD), Automatic Format Detection (AFD), game mode, 3D Color Management, Digital Noise Reduction (DNR), MPEG Noise Reduction, Automatic Channel Install (ACI), NTSC playback on PAL TV
Sound Output Mode
Stereo
Speaker System
2 speakers
Stereo Reception System
NICAM
USB Port
Yes , 1 ports
LCD TV
Diagonal Class
32"
Commercial Use
Hotel / hospitality
Series
REGZA BV Series
TV Tuner
Video Interface
HDMI Ports Qty
2 ports
PC Interface
VGA (HD-15)
HDCP Compatible
Dimensions
With stand
78.8 cm
20.5 cm
55.7 cm
11.05 kg
Enclosure Colour
Display
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Image Aspect Ratio
16:9
Dynamic Contrast Ratio
100000:1
Brightness
500 cd/m2
Widescreen Modes
Conventional 4:3
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Response Time
5 ms
Max V-Sync Rate
50 Hz
Comb Filter
3D digital
Colour Temperature Control
Commercial Features
Hotel mode
Stands & Mounts
Stand
Included
Stand Design
Tabletop
TV Tuner
Analogue TV Tuner
PAL, SECAM
NICAM
Digital TV Tuner
Digital TV Service
FREEVIEW
Digital Channel Qty
800 channels
Video Features
Analogue Video Input Signals
NTSC, PAL, SECAM
Teletext
Teletext Memory
1000 pages
Electronic Programme Guide
Digital EPG
Media Player
USB Port
Yes , 1 ports
Radio
Preset Station Qty
24 channels
Audio System
Sound Output Mode
Stereo
Speaker System
2 speakers
Output Power / Total
12 Watt
Speakers
2 x main channel speaker - built-in - 6 Watt
Connector Type
2 x HDMI ( 19 pin HDMI Type A ) , 1 x VGA / component video input ( 15 PIN HD D-Sub (HD-15) ) , 1 x composite video input , 1 x SCART ( 21 PIN SCART ) , 1 x VGA input ( 15 PIN HD D-Sub (HD-15) ) , 1 x USB ( 4 PIN USB Type A ) , 1 x SPDIF output ( RCA phono ) , 1 x headphones ( mini-phone stereo 3.5 mm )
