Click to visit BT.com
BT.com
Wishlist
Toshiba 2TB MK2001TRKB SAS-D NL 7200RPM 3.5" 16MB
Quicklinx: 7NBXWS00
Mfr#: MK2001TRKB
Essential accessories
The Toshiba MK2001TRKB series hard disk drive features high storage capacities, enterprise-class reliability, and performance efficiencies which are critical to business operations. The high-capacity, cost-effective models feature 7,200 rpm spin speed and leading-edge 6 GB/sec Serial Attached SCSI (SAS) interface. It leverages the expertise and offer similar features as traditional enterprise-class drives including Rotational Vibration (RV) technology for multi-drive systems.
Toshiba MK2001TRKB - hard drive - 2 TB - SAS 6Gb/s
Hard drive - internal
2 TB
3.5"
SAS 6Gb/s
Data Transfer Rate
600 MBps
Buffer Size
16 MB
Spindle Speed
7200 rpm
Rotational Vibration (RV) compensation technology
10.2 cm x 14.7 cm x 2.6 cm
0.8 kg
Microsoft Certification
Compatible with Windows 7
5 years warranty
2 TB
3.5"
SAS 6Gb/s
Buffer Size
16 MB
10.2 cm
14.7 cm
2.6 cm
0.8 kg
Performance
Drive Transfer Rate
600 MBps (external)
Seek Time
9.5 ms (average)
Track-to-Track Seek Time
1 ms
Average Latency
4.17 ms
Spindle Speed
7200 rpm
Reliability
MTBF
1,200,000 hours
Expansion & Connectivity
Compatible Bays
1 x internal - 3.5"
RoHS
5 years warranty
Service & Support Details
Limited warranty - 5 years
5 °C
55 °C
Shock Tolerance
70 g @ 2ms (operating) / 300 g @ 2ms (non-operating)
Vibration Tolerance
0.75 g @ 5-300 Hz (operating) / 5 g @ 5-500 Hz (non-operating)
Sound Emission
30 dB
