BT.com
Wishlist
Toshiba 256GB Q300 Pro 2.5" SATA 6Gb/s SSD
Toshiba 256GB Q300 Pro 2.5" SATA...
£114.34
£114.34
Add to wishlist
Delivery
Standard Due date unavailable
Boost your computer's boot-up and operation performance with Toshiba's 19 nm Solid State Drive technology. With a blazing fast SATA III interface, your computer's performance will make a quantum leap forward. The 7 mm slim SSD includes a spacer you will need for a firm fit in a 9.5 mm hard disk slot and also a cloning software you will need for exchanging your hard drive with the SSD.
Toshiba Q300 Pro - solid state drive - 256 GB - SATA 6Gb/s
Solid state drive - internal
256 GB
NAND Flash Memory Type
15nm single-level cell (SLC)
SATA 6Gb/s
Data Transfer Rate
600 MBps
Native Command Queuing (NCQ), TRIM support, Garbage Collection technology, Quadruple Swing by Code, Zero Trim Support, Adaptive Size SLC Write cache technology, S.M.A.R.T.
69.85 mm x 100 mm x 7 mm
53 g
5 years warranty
256 GB
SATA 6Gb/s
69.85 mm
100 mm
7 mm
53 g
Performance
SSD Endurance
160 TB
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
550 MBps (read) / 510 MBps (write)
4KB Random Read
90000 IOPS
4KB Random Write
58000 IOPS
Reliability
MTBF
1,500,000 hours
Expansion & Connectivity
1 x SATA 6 Gb/s
Power Consumption
3.3 Watt (active) , 125 mW (idle)
Software Included
NTI Echo 3
Mounting spacer
JESD-219A
Package Type
Retail
Limited warranty - 5 years
65 °C
Other bundles
£114.34
Save on Intel Optane 16GB with HDD
Save £5.00
£152.64
Scroll to top
