Click to visit BT.com
BT.com
Wishlist
Toshiba 22" Full HD 1080p LED TV
Quicklinx: 81WJWS00
Mfr#: 22BL702B
Essential accessories
The 22BL702 delivers full high definition 1080p picture quality combined with all the benefits of LED technology for amazing color, brightness and image clarity all in a thin, space-saving, gloss design.
The BL702 series also includes built-in Freeview digital TV access, so you can enjoy subscription-free access to 50 digital TV channels and 24 radio stations without the need for an additional set top box. Video, photo and audio playback is possible via a USB drive and HDMI connectivity and PC inputs make it easy to connect to other digital entertainment devices.
Toshiba 22BL702B REGZA BL Series - 22" LED TV
LED-backlit LCD TV
Energy Class
Class A
45 Watt
Power Consumption (On mode)
21 W
Energy Consumption per Year
31 kWh
Diagonal Class
22"
Commercial Use
Hotel / hospitality
53 cm x 15.2 cm x 37.6 cm - with stand
4.25 kg
Resolution
1366 x 768
Display Format
720p
Video Interface
Component, composite, HDMI, SCART
HDMI Ports Qty
1 ports
PC Interface
VGA (HD-15)
HDCP Compatible
LCD Backlight Technology
LED backlight
Image Aspect Ratio
16:9
TV Tuner
1x analogue, 1x digital
Analogue TV Tuner
PAL, SECAM
Commercial Features
Hotel mode
Settings Cloning Capability
Audio Description (AD), Automatic Format Detection (AFD), game mode, 3D Color Management, Digital Noise Reduction (DNR), MPEG Noise Reduction, Automatic Channel Install (ACI), NTSC playback on PAL TV
Sound Output Mode
Stereo
Speaker System
2 speakers
Stereo Reception System
NICAM
USB Port
LED-backlit LCD TV
Energy Class
Class A
45 Watt
21 W
31 kWh
Diagonal Class
22"
Commercial Use
Hotel / hospitality
Series
REGZA BL Series
TV Tuner
Video Interface
HDMI Ports Qty
1 ports
PC Interface
VGA (HD-15)
HDCP Compatible
Dimensions
With stand
53 cm
15.2 cm
37.6 cm
4.25 kg
Display
Resolution
1366 x 768
Display Format
720p
Image Aspect Ratio
16:9
LED backlight
Dynamic Contrast Ratio
3000000:1
Brightness
300 cd/m²
Widescreen Modes
Conventional 4:3
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Response Time
9 ms
Max V-Sync Rate
50 Hz
Comb Filter
3D digital
Colour Temperature Control
Commercial Features
Hotel mode
Stands & Mounts
Stand
Included
Stand Design
Tabletop
TV Tuner
Analogue TV Tuner
PAL, SECAM
NICAM
Digital TV Tuner
Digital TV Service
FREEVIEW
Digital Channel Qty
800 channels
Video Features
Analogue Video Input Signals
NTSC, PAL, SECAM
Teletext
Teletext Memory
1000 pages
Electronic Programme Guide
Now & Next
Media Player
USB Port
Radio
Preset Station Qty
24 channels
Audio System
Sound Output Mode
Stereo
Speaker System
2 speakers
Output Power / Total
5 Watt
Speakers
2 x main channel speaker - built-in - 2.5 Watt
Connector Type
1 x HDMI ( 19 pin HDMI Type A ) , 1 x VGA / component video input ( 15 PIN HD D-Sub (HD-15) ) , 1 x composite video input , 1 x SCART ( 21 PIN SCART ) , 1 x USB ( 4 PIN USB Type A )
Power supply
Power Consumption Stand by / Sleep
0.5 Watt
