BT.com
Wishlist
Toshiba 1TB 2.5" 5400 8MB SATA300
Delivery
Standard Due date unavailable
The MKxx59GSM series of SATA drives target today's massive digital content needs with capacity points typically supported by larger form factor 3.5-inch drives. Design elements of the MKxx59GSM series drive include advanced sector format technology, which utilize the industry standard 4K byte-per-sector configuration and improved error-correcting code functionality to enhance data integrity while making more efficient use of the storage surface area. Furthermore, Toshiba's environmental initiatives including lower power consumption techniques and components that reduce reliance on harmful chemicals, materials and compounds are also represented in the MKxx59GSM design. The MKxx59GSM series drive is designed to support strong growth segments for high-capacity storage purposes including external add-on storage and tape replacement products as well as, docking stations, gaming notebooks, mobile work stations and other capacity-hungry applications.
Toshiba MK1059GSM - hard drive - 1 TB - SATA 3Gb/s
Hard drive - internal
1 TB
SATA 3Gb/s
Data Transfer Rate
300 MBps
Buffer Size
8 MB
Spindle Speed
5400 rpm
70 mm x 100 mm x 12.5 mm
148 g
Microsoft Certification
Compatible with Windows 7
1 year warranty
1 TB
2.5" x 1/8H
SATA 3Gb/s
Buffer Size
8 MB
70 mm
100 mm
12.5 mm
148 g
Performance
Drive Transfer Rate
300 MBps (external)
Seek Time
12 ms (average)
Track-to-Track Seek Time
2 ms
Average Latency
5.55 ms
Spindle Speed
5400 rpm
Expansion & Connectivity
1 x SATA 3 Gb/s
Compatible Bay
2.5" x 1/8H
1 year warranty
Limited warranty - 1 year
5 °C
55 °C
Shock Tolerance
400 g @ 2ms (operating) / 900 g @ 1ms (non-operating)
Vibration Tolerance
1 g @ 5-500 Hz (operating)
Sound Emission
25 dB
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
3* Bigger than your average drive (Literally!)
Reviewed by Neil Westlake on 22/10/2010
If you're ordering these drives make sure you check they will fit. They are higher than a standard 2.5" drive which is 9.5mm these are 12.5mm which means they won't fit in some cases.
Scroll to top
