BT.com
Wishlist
Toshiba 1024GB Q300 Pro 2.5" SATA 6Gb/s SSD
Delivery
Standard Due date unavailable
Boost your computer's boot-up and operation performance with Toshiba's 19 nm Solid State Drive technology. With a blazing fast SATA III interface, your computer's performance will make a quantum leap forward. The 7 mm slim SSD includes a spacer you will need for a firm fit in a 9.5 mm hard disk slot and also a cloning software you will need for exchanging your hard drive with the SSD.
Toshiba Q300 Pro - solid state drive - 1024 GB - SATA 6Gb/s
Solid state drive - internal
1024 GB
NAND Flash Memory Type
15nm multi-level cell (MLC)
2.5"
SATA 6Gb/s
Data Transfer Rate
600 MBps
Native Command Queuing (NCQ), TRIM support, Garbage Collection technology, Quadruple Swing by Code, Zero Trim Support, Adaptive Size SLC Write cache technology, Toshiba TC358790 controller, S.M.A.R.T.
69.85 mm x 100 mm x 7 mm
53 g
5 years warranty
1024 GB
2.5"
SATA 6Gb/s
69.85 mm
100 mm
7 mm
53 g
Performance
SSD Endurance
640 TB
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
550 MBps (read) / 520 MBps (write)
4KB Random Read
92000 IOPS
4KB Random Write
63000 IOPS
Reliability
MTBF
1,500,000 hours
Expansion & Connectivity
1 x SATA 6 Gb/s
Compatible Bay
2.5"
Power Consumption
3.3 Watt (active) , 125 mW (idle)
Software Included
NTI Echo 3
Mounting spacer
Limited warranty - 5 years
65 °C
Scroll to top
