BT.com
Wishlist
Thrustmaster TMX Pro Racing Wheel
£155.06
More than 50 in stock
£155.06
Add to wishlist
Delivery
Standard 3-5 working days
Feel like you're behind the wheel of a high-powered race car with this Thrustmaster TMX Pro racing wheel for Xbox One and PC. Featuring a competition size of 28cm and a 900-degree force feedback system that brings every in-game bump to life, this Pro racing wheel includes the T3PA wide 3-pedal set with progressive resistance brake pedal.
Product Info
  • Officially designed for instant plug-and-play use with the Xbox One console and is compatible with Windows 10, 8, 7, and Vista via downloadable drivers
  • Includes the Thrustmaster T3PA wide 3-pedal set that features metal construction on the pedals and internal structure, adjustable pedals, and a brake pedal with progressive resistance
  • Realistic high-performance racing wheel measures 11" (28cm) in diameter and features a comfortable ergonomic design, perfectly adapted for Xbox One racing games that support a racing wheel
  • 900-degree force feedback system brings the on-screen action to life, letting you feel every hard brake, subtle bump, loss of tire grip, and change in road surface
  • Mixed-belt pulley and gears system delivers a smoother and more fluid experience than wheel sets that feature noisy helical gears
  • Metal ball-bearing axle gives the wheel set base a solid, sturdy, and durable build that will stand up to the rigors and stresses of competitive digital racing
  • Wheel rotation angle is adjustable to between 270 and 900 degrees so you can tailor it to your exact preferences
  • Equipped with 2 large, wheel-mounted sequential paddle shifters with full metal construction and integrated Tact switch
  • Built-in official Xbox One buttons and directional pad allow you to switch between the game and the system, navigate system menus, access social functions, and more
  • Compatible with the Thrustmaster TH8A shifter (sold separately)
ThrustMaster TMX PRO - wheel and pedals set - wired
Wheel and pedals set
Wired
2 years warranty
PC, Microsoft Xbox One
Wired
USB
Game Controller (1st) Details
Wheel
Controls
Guide button, D-pad, action buttons
Force feedback, sequential paddle shifters
Game Controller (2nd) Details
Pedals
Adjustable pedal angle
Buy used stock
What is used stock?
Used stock is a great opportunity to bag yourself a bargain. There are many reasons why a product may be classed as used stock ranging from missing manuals or software to simply having been opened or having damaged packaging. Some items may have been repaired under warranty. Rest assured though that all used stock comes with a 6 month warranty and is in good working order. You can find out the exact details about each product using the key below.
Item condition Damaged stock - Item is new but has packaging damage
Ref: CNM4 036213
  • Accessories
  • Packaging
  • Functional
  • Software
  • Manuals
£141.22
What does this mean?
  • This part of the stock item is present and in good condition
  • This part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.
Scroll to top
