BT.com
Wishlist
ThrustMaster T500 RS - Racing Wheel and pedals set - PS3/PC
Delivery
Standard Due date unavailable
The new benchmark force feedback wheel! Realistic Simulator, with official GRAN TURISMO®5 & PlayStation® Licences
Realistic wheel
- Authentic wheel:
30cm (12") in diameter with brushed metal central spokes
Detachable (allows for future upgrades)
- Authentic sequential gearshift levers: crafted of brushed metal, attached to the base (so they don't move with the wheel)
- 17cm in height (for instant access along 1080°)
Precision, Force Feedback & realistic angle of rotation:
- New H.E.A.R.T HallEffect AccuRate Technology™ on the wheel's steering:
Ultra-precise wheel, with 16-bit resolution (65536 values on the steering)!
Precision that won't decrease over time (contactless magnetic sensor)
- Force Feedback with industrial motor (Torque 150mNm, 3000rpm, 65W, Ø 52mm/2")
Super-powerful, quick responding Force Feedback mechanism
Rigid motorized stopper, no matter what angle of rotation you select
- Mechanism with large dual belts (fluid and smooth action)
- Angle of rotation adjustable up to 1080° (3 full turns)!
Realistic pedal set
-Unique design with your choice of 2 positions:
Floor-mounted position (F1-style)
Suspended position (GT-style)
- 100% metal, for optimal stability, weight (more than 7 kgs) and resistance
- 3 100% adjustable pedals (spacing between the pedals/height)
- Brake pedal with reinforced and adjustable resistance (included and removable "Realistic Brake" mod)
- Included metal footrest with non-slip grating texture
ThrustMaster T500 RS - wheel and pedals set - wired
Wired
Force feedback, adjustable steering angle, H.E.A.R.T HallEffect AccuRate Technology
Sony PlayStation 3
Wired
Sony PlayStation 3
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
5* Fantastic Product
Reviewed by Darius on 09/11/2013
This is a fantastic wheel in both build quality and functionality. While it is compatible with the PS3 it is only with a few games so I would only recommend it for PC users.
Currently tested it on Richard Burns Rally, F1 2012, Grid 2, Rfactor 2, WRC 3 and works great on all of them.
I've ordered the TH8RS shifter which I think will compliment the wheel perfectly.
It's not cheap by any means but if you want to take simulation racing seriously it is extremely good value for money.
5* Great wheel and pedal kit
Reviewed by Foomandoo on 12/04/2014
Firstly this is one solid bit of kit, the pedals weigh in at 7kg and stay where you put them and the wheel is about the same. (be aware delivery will be slightly higher due to extra weight) Not had much chance to use this yet but it works great in Race07 although I did have to faff a bit to get it configured correctly hence only 4 out of 5 for ease of use. Force feedback is powerful - make sure you keep your hands (and small children) away from the wheel when you plug it in, it could easily do some damage. The wheel is solid and has NO dead zone, yay. You can adjust the spacing of the pedals which is handy if you have big feet and the whole pedal assembly can be flipped to allow F1 or GT style pedal movement which is great (press the Mode button to swap the clutch/accelerator pedals) I was going to drop a point for value purely because £330+ for a game accessory is excessive but it is head and shoulders above all the other wheels out there and BT is the cheapest by far.
Scroll to top
