BT.com
Wishlist
Thrustmaster T.16000M Joystick PC
Delivery
Standard Due date unavailable
This Thrustmaster T.16000M joystick uses exclusive high-precision technology to bring you a breathtaking experience in 3D games!
The T.16000M can be used by both left-handed and right-handed users, and features 3D Hall Effect magnetic sensors that are 256 times more accurate than those used in regular joysticks. It also has 16 buttons and 4 independent axes, as well as a hand-rest for comfortable gaming no matter how long you play!
The affordable Thrustmaster T.16000M is a high-precision joystick that will revolutionise your PC gaming!
Type: Joystick
Compatible platforms: Windows XP, Windows Vista
Connectivity: USB
Controls: 16
Other features:
Switch for setting the 12 base buttons to left-handed or right-handed use
4 independent axes
Rudder control by rotating the handle
Brake trigger (civil flight) or rapid fire (military flight)
Multidirectional hat switch (for panoramic view)
Wide hand-rest reduces tiredness
Filled base for greater stability
Wireless: Yes
System Requirements: Self-powered through USB
ThrustMaster T.16000M - joystick - wired
Joystick
Wired
Buttons Qty
16
PC
Joystick
Wired
Buttons Qty
16
USB
1 x USB - 4 pin USB Type A
Plug and Play
PC
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
5* Great Joystick
Reviewed by Anonymous on 24/09/2013
Very useful to find that this joystick can be readily changed to left handed operation.
Operation is very smooth, although some of the thumb buttons feel a little vague. The Top Hat is great. There is too much movement on the main trigger. Apart from that, it's all good.
Software is downloaded from the Thrustmaster site and is excellent.
The only problem I found with this Joystick is that many games thought it was an xbox controller.
Very good value for the money. If the Hall Effect units last as long as they should, then this is a bargain.
5* Thrustmaster T16000M
Reviewed by S1rmunchalot on 01/10/2014
I bought 2. To use with a new game coming out called Star Citizen. They are extremely accurate, good solid responsive feel without being heavy. Extremely easy to set left/right hand versions. They are a real joy to use. You can download the Thrustmaster TARGET software which will give endless options including combining both sticks so that Windows reports a single controller.
I have heard 2 complaints from others:
The brightness of the LED's - can be dimmed/switched off in TARGET.
The slider(throttle) is 'jumpy'. Both are smooth as silk on mine. Only gripe would be that the 'throw' of the slider could be longer, handle very carefully. Shoving them about makes it look as though they are 'jumpy'.
Wish there was a twist 'lock' feature.
I would buy them again in a heartbeat, at this price they can't be beaten. I have 9 other controllers some costing £100's but these are now my favourites. I wish my Saitek Pro Flight controllers were this accurate and smooth.
5* thrustmaster t-16000M
Reviewed by Anonymous on 04/01/2014
I hope it is going to be worth the money
Scroll to top
