Click to visit BT.com
BT.com
Wishlist
Thrustmaster Hotas Warthog Joystick and Throttle for PC
Dual throttle control & 19 action buttons!
5.0*
Quicklinx: 75W2WS00
Mfr#: 2960720
Type: Throttle
Wired / Wireless: Wired
Compatibility: PC
24 in stock
£249.01
The Hotas Warthog™ is an U.S. Air Force A-10C attack aircraft HOTAS™ (Hands On Throttle And Stick) replica joystick high end system including:
Dual Replica THROTTLES
Software suite: T.A.R.G.E.T (Thrustmaster Advanced pRogramming Graphical EdiTor)
Replica JOYSTICK
Replica A-10 Flight Stick
Innovative new H.E.A.R.T HallEffect AccuRate Technology:
- 3D magnetic sensors (Hall Effect) on the stick: enjoy surgical precision that stays razor-sharp over time
- 16-bit resolution (65536 x 65536 values)
- 5 coil spring system: firm, linear and fluid tension, with no dead zones
USB connection with upgradeable firmware
Super-stable, weighted base (over 3kg)
New detachable handle, crafted entirely of metal:
- also compatible with HOTAS COUGAR™ handle (and vice-versa)
- new replica shape
- detachable metal plate for desk- or cockpit-style use
- new, realistic pressure on buttons and trigger
- 19 action buttons in total + one 8-way "point of view" hat:
. 1 x 8-way "point of view" hat
. 2 x 8-way hats
. 1 x 4-way hat with push button
. 1 x metal dual trigger
. 2 x push buttons
. 2 x pinkie push buttons
- 3D magnetic sensors (Hall Effect) on the 2 throttles: enjoy surgical precision that stays razor-sharp over time
- 14-bit resolution (16384 values) on each throttle
Dual throttles, featuring:
- metal hand rest
- locking system
- adjustable friction system: firm, linear and fluid tension, with no dead zones
- realistic IDLE detent with "Pull & Push" system
- realistic and disengageable AFTERBURNER detent with "Pull & Push" system
- realistic pressure on buttons and switches
- 17 action buttons in total + 1 mouse hat with push button + one 8-way "point of view" hat:
. 1 x mouse hat with push button and 3D magnetic sensor (Hall Effect)
. 1 x 8-way hat
. 1 x push button
. 1 x 3-position switch (2 momentary + 1 permanent)
. 2 x 3-position switches (3 permanent)v . 1 x 3-position switch (1 momentary + 2 permanent)
Replica Control Panel
Weighted base (over 3kg) incorporated underneath the throttles
Backlit functions
5 programmable LEDs
Realistic pressure on buttons and switches
15 action buttons in total + 1 TRIM wheel:
. 1 x TRIM wheel
. 2 x push buttons
. 5 x 2-position switches (2 permanent)
. 2 x 3-position switches (1 momentary + 2 permanent)
SOFTWARE SUITE: T.A.R.G.E.T (Thrustmaster Advanced programming graphical editor)
To test, configure and program Thrustmaster® controllers: HOTAS WARTHOG™, MFD Cougar, HOTAS Cougar™ and T.16000M
Uses the "Drag and Drop" principle
Multiple programming levels: Basic, Advanced and Script
Thrustmaster HOTAS Warthog - joystick and throttle - wired
Joystick and throttle
Wired
Dual throttle control, H.E.A.R.T HallEffect AccuRate Technology
PC
Wired
USB
2 x USB - 4 pin USB Type A
Software Included
PC
Thrustmaster Hotas Warthog Joystick and Throttle for PC Bundle deal on Thrustmaster Hotas Warthog Joystick and Throttle for PC
Including:
Corsair Flash Voyager Slider - 32GB - USB 3.0 Corsair Flash Voyager Slider - 32GB - USB 3.0 worth £14.98 | while stocks last
£259.00
saving £4.99
Including:
Intenso 32GB Rainbow Transparent USB Flash Drive Intenso 32GB Rainbow Transparent USB Flash Drive worth £4.98 | in stock
£253.10
saving £0.88
Customer reviews
Write a review for the Thrustmaster Hotas Warthog Joystick and Throttle for PC here!
Awesome
Reviewed by Clive. Review Posted 03/11/2010
If military flight sims are your thing then I cannot recommend this item enough.
Its a quality item, extremely well built and I am chuffed to bits with it.
11 out of 10!
  • Overall 5*
  • Ease of use 5*
  • Value for money 5*
The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
Type: Throttle
Compatibility: PC
Brand: Thrustmaster
Price Range Inc VAT: 150 - 300
