BT.com
Wishlist
Thermaltake Core X2 MATX Window
Delivery
Standard Due date unavailable
Core X2, the first mATX chassis of Core X Series presented by Thermaltake, is a cube case offering endless stackable capacity and expandability for enthusiasts to create massive liquid cooling systems, utilize as a file server as well as accommodate dual systems. Users can customize the chassis for the best viewing presentation with an interchangeable window and I/O panel design. The Core X2 delivers outstanding cooling performance with compatibility for extensive DIY/AIO LCS and overclocking components, further enhancing the reputation that the air-cooling units of this series has become renowned for. It is guaranteed to be an immensely powerful system!
Thermaltake Core X2 - cube - micro ATX
System cabinet
Cube
I/O Connectors
2 x USB 3.0 , 1 x microphone , 1 x headphones/speakers
Supported Motherboards
microATX, Mini-ATX
System Cabinet Features
Windowed side panel, supports 120/240 mm radiator in bottom, supports 120/140/240/280/360 mm radiator in front panel, supports 1/2", 3/8",1/4" water tube, stackable, supports 1 x 140/280 or 2 x 120/240/360 mm radiators in top, supports 120/240/360 mm radiator in side panel, supports 120/140 mm radiator in rear
No power supply
Specification Compliance
PS/2
46.5 cm x 32 cm x 54.1 cm
11.6 kg
Cube
Max Mainboard Size
Micro ATX
microATX, Mini-ATX
PS/2
Internal Bays Qty
7
Front Accessible Bays Qty
3
Cooling System
Front: 120 x 120 x 25 mm fan x 1 / intake / 1000 rpm / 16 dBA / TurboFan, 1 x 200 mm fan or 2 x 140 mm fan or 3 x 120 mm supported , Rear: 120 x 120 x 25 mm fan x 1 / exhaust / 1000 rpm / 16 dBA / TurboFan, 1 x 120/140 mm fan supported , Top: 120 mm fan mount x 6 / 2 x 140/200 mm fan supported , Bottom: 120 mm fan mount x 2 , Side: 120 mm fan mount x 3
CPU Cooler Max Height
230 mm
Video Card Max Length
330 mm
Expansion Bays
3 (total) / 3 (free) x front accessible - 5.25" , 4 (total) / 4 (free) x internal - 2.5" / 3.5" shared , 3 (total) / 3 (free) x internal - 2.5"
Expansion Slots
5
2 x USB 3.0 , 1 x microphone - mini-jack , 1 x headphones/speakers - mini-jack
No power supply
46.5 cm
32 cm
54.1 cm
11.6 kg
Scroll to top
