BT.com
Wishlist
Thermaltake Contac 21 CPU Cooler
Delivery
Standard Due date unavailable
Heat-pipe Direct Touch Technology with Excellent Performance, supports 140W
Four 6mm Heat-pipes provide good contact with CPU and enhance heat transfer. Premium thermal grease provides higher thermal conductivity between CPU and cooler.
Pre-installed one 92mm high performance fan
PWM function with fan speed from 1000~2400RPM. Enclosed two clips for 2nd fan installation to increase cooling performance.
Universal Socket Compatibility
Support: Intel socket LGA 1366/1155/1156/775 + AMD socket FM1/AM3+/AM3/AM2+/AM2
Specification
  • Heatsink Dimension 100(L) x 88.4(W) x 139.5(H) mm
  • Heatsink Material Aluminum Fins + Aluminum Base
  • Heatpipe 6mm x 4
  • Fan Dimension 92(L) x 92(W) x 25(H) mm
  • Rated Voltage 12 V
  • Started Voltage 6 V
  • Rated Current 0.24A
  • Power Input 2.88W
  • Fan Speed 1000 ~ 2400 RPM (PWM)
  • Air Flow 17.2 ~ 45.4 CFM
  • Air Pressure 0.5 ~ 2.6 mmH2O
  • Noise 19.3 ~ 30 dBA
  • Life Expectation 30,000 Hours
  • Connector 4 Pin
  • Weight 425 g
Thermaltake Contac 21 - processor cooler
Processor cooler
Compatibility
LGA775 Socket, LGA1156 Socket, Socket AM2, Socket AM2+, Socket AM3, LGA1155 Socket, Socket AM3+, Socket FM1, LGA1150 Socket
Heatsink Material
Aluminium
Fan Diameter
92 mm
Fan Height
25 mm
Rotation Speed
1000-2400 rpm
Air Flow
17.2-45.4 cfm
Noise Level
19.3 - 30 dBA
Power Connector
4-pin fan connector
Rated Voltage
12 V
Heat pipe technology
425 g
Processor cooler
425 g
Heatsink & Fan
Compatible With
Processor Compatibility
Core 2 Extreme , Core i7 , Core i5 , Core i3 , Core 2 Quad , Core 2 Duo , Pentium D , Pentium 4 , Pentium , Celeron D , Celeron , Athlon II , Phenom II , Athlon , Sempron , Phenom
Heatsink Material
Aluminium
Heatsink Dimensions
139.5 mm x 100 mm x 88.4 mm
Fan Diameter
92 mm
Fan Height
25 mm
Rotation Speed
1000-2400 rpm
Air Flow
17.2-45.4 cfm
Air Pressure
0.5-2.6 mm
Noise Level
19.3 - 30 dBA
Power Connector
4-pin fan connector
Rated Voltage
12 V
Start Voltage
6 V
Rated Current
0.24 A
MTBF
30,000 hour(s)
Scroll to top
