BT.com
Wishlist
Techair iPad mini Folio Case
£12.78
More than 50 in stock
£12.78
Add to wishlist
Delivery
Standard 3-5 working days
This stylish folio case with its stunning soft-touch scarlet lining is both a professional and practical accessory for your iPad. The lining will help protect your iPad, the "book" opening format of this folio case makes it easy to use your iPad when on the move, and the integral "unfolding" stand makes it easy to view and use it when you want to place your iPad down on a table or desk. 5 position stand with complete access to all controls, functions and ports with precise cut outs.
Techair Folio - case for tablet
Case for tablet
14 cm x 1.6 cm x 20.5 cm
100 g
Material
Polyurethane
Apple iPad mini
14 cm
1.6 cm
20.5 cm
100 g
Material
Polyurethane
Carrying Case
Case
Recommended Use
For tablet
Closure Type
Magnetic closure
Compartments Quantity
1 compartments
Inner Dimensions
13.5 cm x 0.8 cm x 20 cm
Hidden AutoWake magnets
Cover Features
Stand function
Service & Support Details
Lifetime
Apple iPad mini
Buy used stock
What is used stock?
Used stock is a great opportunity to bag yourself a bargain. There are many reasons why a product may be classed as used stock ranging from missing manuals or software to simply having been opened or having damaged packaging. Some items may have been repaired under warranty. Rest assured though that all used stock comes with a 6 month warranty and is in good working order. You can find out the exact details about each product using the key below.
Item condition Customer return - item has been used and shows signs of use
Ref: 9GDJ 034430
  • Accessories
  • Packaging
  • Functional
  • Software
  • Manuals
£1.80
Ref: 9GDJ 034431
  • Accessories
  • Packaging
  • Functional
  • Software
  • Manuals
£1.80
What does this mean?
  • This part of the stock item is present and in good condition
  • This part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.
Scroll to top
