Click to visit BT.com
BT.com
Wishlist
TBS Dual DVB-T2 PCIe TV Tuner Card
5.0*
Quicklinx: 7KTRWS00
Mfr#: TBS6280
TBS6280 PCI-E DVB-T2/T Dual Tuner Card
TBS6280 is a dual tuner PCI-Express interface DVB-T2/T TV Tuner Card which supports watching or recording two different channels from two different frequencies simultaneously.
TBS 6280 can be used as a digital video recorder for recording digital terrestrial TV programs with full HDTV support.
It also enables you to pause a live broadcast and continue from where you left with the Time-shifting function.
This DVB T2 PC TV card is ready with windows BDA driver and Linux driver. It's ideal for watching UK Freeview SD and HD channels on your PC.
Please ensure you can receive the Digital Terrestrial Television (DVB-T, DVB-T2,Freeview) service in your region.
The TBS 6280 requires you use a high-gain roof aerial to enable and enjoy reliable Digital Television reception throughout the UK.
Low Profile Size High-Definition Video, Real-Time and Scheduled Video Recording High Sensitivity DVB-T2 Dual Tuner for The Best Digital TV Reception
Package Contains:
1 x PCI-E DVB-T2 Dual Tuner card 1x Remote control 1x IR receiver 1x Low profile bracket 1x Mini Antenna 1x Software CD
Features:
Dual Channels Receiving to Watch and Record Synchronously
Listen to Digital Stereo Radio (DVB-T radio)
High Sensitivity DVB-T2 Tuner for the Best Digital TV Reception
Both DVB-T2 and DVB-T are supported
Specifications: Receiving Channel: VHF Band and UHF Band
Channel Bandwidth: 6, 7, 8 MHz
DVB-T2/T Modulation Type: QPSK, 16QAM, 64QAM, 256QAM
FFT mode: 1K, 2K, 4K, 8K, 16K, 32K
Code Rate: 1/2, 3/5, 2/3, 3/4, 4/5, 5/6
Guard Internal: 1/4, 1/8, 1/16, 1/32, 1/64, 1/128, 19/128, 19/256 Intermediate Frequency
IF Mode: Low IF
Center IF Frequency: 3 ~ 5 MHz
Note: default 4MHz
RF-Input Impedance 75O (IEC-DIN female)
RF-Output Impedance 75O (IEC-DIN male)
SAMSUNG Dual DVB-T2 NIM Tuner
NXP SAA7160ET PCI-Express bridge
Minimum System Requirements
Windows XP / Vista/ 7, Linux
Pentium 4 2.0 GHz, PentiumM 1.3 GHz
For HDTV: 2.6 GHz multi core processor
Hard disk with min. 1 GB free capacity
Sound and graphics card with support for DirectX 9 or higher
One free PCI Express slot
CD/DVD drive for software installation
Incl Loop Through AE
Digital TV Card
Digital TV Tuner / Digital TV Tuner Type
DVB-T2
PCI Express x1
Header / Country Kits
United Kingdom
Interface Provided / Type
TV antenna
Header / Localization
English
TV Tuner / Reception System
DVB-T2
System Requirements Details / Processor Speed
2.6 Ghz Dual Core
Digital TV Tuner / Tuner Qty
2
Dimensions & Weight / Weight
0.364 kg
Customer reviews
Write a review for the TBS Dual DVB-T2 PCIe TV Tuner Card here!
TBS 6280
Reviewed by brio. Review Posted 24/09/2011
Works well on Linux Mythtv in DVBT-2 HDTV mode. But you will need the latest drivers off the TBS forum.
  • Overall 5*
  • Ease of use 4*
  • Value for money 4*
The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
