BT.com
Wishlist
Tascam DR-40 Voice Recorder
£207.82
£207.82
Add to wishlist
Delivery
Standard Due date unavailable
The Tascam DR-40 packs four-track recording, adjustable condenser microphones, XLR mic inputs and extended battery life into a portable recorder you can take anywhere. It captures up to four tracks from built-in microphones, external mics or line level sources. The high-quality internal microphones are adjustable from XY to AB position, helping you to tailor your recording to the sound source. A pair of great-sounding Tascam microphone preamps welcome condenser microphones with phantom power, recording at up to 96kHz/24-bit resolution. It accommodates balanced XLR or 6.3mm line inputs using locking Neutrik combo jacks. The DR-40 accepts SD or SDHC cards up to 32GB.
Tascam DR-40 - voice recorder
Voice recorder flash based
Components
Digital voice recorder
Playback Digital Standards
WAV, MP3, BWF
Supported Flash Memory Cards
SDHC, SD Memory Card
Speakers
1 x speaker - 0.3 Watt
Microphone
Stereo microphone - built-in - cardioid, omni-directional
USB 2.0
3 x AA type
Voice recorder
Digital Player Type
Flash based
USB Specification Version and Speeds
USB 2.0
Interface Supported
USB 2.0
Supported Digital Audio Standards
WAV, MP3, BWF
Audio System
Components
Speaker System
Speakers
Digital Player (Recorder)
Variable Speed Playback
Microphone
Microphone Operation Mode
Cardioid, omni-directional
Connector Type
USB 2.0 (mini-USB Type B) , Audio line-in / microphone (XLR) , Audio line-out (mini-phone stereo 3.5 mm)
USB cable
1 x USB cable
Power adapter
Internal Battery
3 x AA type
Apple MacOS X 10.2 or later, Microsoft Windows Vista / XP / 7
Scroll to top
